3 Replies Latest reply on Feb 3, 2011 11:22 AM by Shongrunden
    Flex 4 and disabledOverlayAlpha
    thimmaiah.chendrimada
      Im migrating from Flex 3. My app use to display forms in readonly mode by setting the Panel enabled=false and setting its disabledOverlayAlpha=0 so that the readonly form would not look greyed out but would be disabled.
      Now Flex 4 does not support this style disabledOverlayAlpha for spark Panels and BorderContainers. Is there a simple way to do this without skinning the component ?
      Thanks in advance
      Regards
      T
        • 1. Re: Flex 4 and disabledOverlayAlpha
          Shongrunden Adobe Employee
          A custom skin would probably be the best approach, but you could set the alpha on the skin to 1 without custom skinning like this:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <s:Panel id="panel" title="Test" creationComplete="panel.skin.alpha=1"  enabled="false">
                  <s:Button label="test" />
              </s:Panel>
          </s:Application>
          This example just changes the alpha to 1 at creationComplete time.  If you later change the enabled value to true you will probably have to update the skin alpha again as well.
          • 2. Re: Flex 4 and disabledOverlayAlpha
            thimmaiah.chendrimada Level 1
            I tried this but the panel still looks grayed out. Any suggestions ?
            My code
            <UserRequestDetailsPanel id="userRequestDetailsPanel" enabled="false"
               creationComplete="{userRequestDetailsPanel.skin.enabled = true}"
               height="400" maxWidth="800"/>
            • 3. Re: Flex 4 and disabledOverlayAlpha
              I'd have to see your application to know why, but it looks like you will want to use a custom skin.
              Another alternative would be to wrap the Panel in a Group and set disabledAlpha on that Group:
                  <s:controlBarContent>
                      <s:CheckBox label="enabled" id="chk" />
                  </s:controlBarContent>
                  <s:Group id="group1" enabled="{chk.selected}" disabledAlpha="1">
                      <s:Panel id="panel" title="Test">
                      </s:Panel>
                  </s:Group>
              </s:Application>
