3 Replies Latest reply on Jun 21, 2007 12:54 PM by Newsgroup_User
    BudAPI OpenFile Problem in MAC
    Ratnabharati Level 1
      I m very new to Director. I want to open a pdf file from my projector on clicking a button.
      I m usinf the "OpenFile" method of BudAPI Xtra. Its working fine in the PC. I m following the cross platform method.
      So, I m publishing my Director file for MAC(hqx version) from PC. While publishing its not showing any error.
      However, the file is not working in the MAC. Is not opening the pdf file.
      Please, help........!!!!! Its very urgent.
      Bharati
        • 1. Re: BudAPI OpenFile Problem in MAC
          Level 7
          Are there any error messages thrown when you run it on the Mac? What
          does the value returned from the baOpenFile() method tell you? Can you
          post some code?
          • 2. Re: BudAPI OpenFile Problem in MAC
            No...Its not showing any error message.
            Following the code:
            on mouseUp
            baOpenFile(the moviePath & "SmartTabs QuickStart Guide.pdf", "0")
            end
            This code is working fine in the PC. Its opening the pdf. However, not working in the MAC. :(
            • 3. Re: BudAPI OpenFile Problem in MAC
              Level 7
              > on mouseUp
              > end
              What is the "0" parameter supposed to be? If you read the documentation
              for the xtra, there are 4 possible values for the second parameter that
              baOpenFile() takes.
              Also, the function returns a value that can provide useful information.
              on mouseUp me
              OK = baOpenFile(the moviePath & "SmartTabs QuickStart Guide.pdf",
              "Normal")
              if OK < 32 then
              -- error occurred; check the docs for numbers and their meaning
              end if
              end
