2 Replies Latest reply on Jun 21, 2007 9:43 AM by Alan Musselman
    9-slice issue
      Anyone else having an issue with the 9-slide guide and "punched-out" symbols?
      I have a large square in which I've punched out a rounded rectangle (using it as a way to frame my site with rounded corners). When i make it a symbol and apply the 9-slice guide, then try to adjust the size, the "punched-out" region is no longer punched out.
        • 1. Re: 9-slice issue
          Level 7
          I tried creating what you describe but am not seeing the problem.
          9-slice behaves as it should.
          I converted the punched out rectangle as a graphic symbol.
          WinXP SP2 -
          alex
          • 2. Re: 9-slice issue
            Level 1
            Post the PNG if you dont mind, it will help us see what you are experiencing...
