1. Re: DPX sequence performance
SteveHoeg Feb 1, 2011 2:41 PM (in response to OneOfTheseWillBeAvailable)My RAID is around 450MB/s and I can play 2K DPX in realtime. Not sure if yours is just slightly too slow.
2. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 1, 2011 3:26 PM (in response to SteveHoeg)It might be slightly too slow, but it's not five times too slow.
And in any case, an R210 AVI is a very similar, if not actually more difficult, load.
Also, the load works out at 200MB/s, which is less than it benchmarks.
And Blackmagic Media Express will read and write DPX files to it.
So no, it isn't too slow. Any other ideas?
(By the way, I apologise for the ridiculous user ID - it was about the only thing I could find that wasn't in use)
Best,
Phil
3. Re: DPX sequence performance
JSS1138 Feb 1, 2011 4:16 PM (in response to OneOfTheseWillBeAvailable)I apologise for the ridiculous user ID - it was about the only thing I could find that wasn't in use)
You could have used your real name. Many of us here do.
By the way, what's an R210 AVI file?
4. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 1, 2011 4:26 PM (in response to JSS1138)Actually I couldn't, That's the first thing I tried!
Anyway.
R210 is the 10-bit RGB uncompressed codec commonly used when working with video from things like Blackmagic and Aja boards. The Blackmagic implementation, which is by far the most common, has a glitch in the decoder which causes a rather complex luminance scaling behaviour and makes it unusable. It is actually quite widely used, because the behaviour is subtle and only readily detectable with test charts, but the thing is broken and horribly so. Blackmagic know about this and don't seem to care, which is why I wanted to go to DPX in the first place.
The point, as far as this discussion goes, is that an R210 AVI is, with audio, actually a larger disk loading than a DPX file. And Premiere Pro will read R210 AVI on my computer. But it won't read DPX.
For a long time it was fairly clear that Adobe didn't intend stills sequences to be used for realtime playback - since they were pushing DPX so heavily I rather hoped that had changed. To read stills sequences efficiently requires a little thought put into things like buffering and possibly multi-threaded reading, which is work I suspect Adobe have not done.
Best,
P
5. Re: DPX sequence performance
JSS1138 Feb 1, 2011 4:29 PM (in response to OneOfTheseWillBeAvailable)Ah. Got it.
I knew the codec used by AJA is V210. Didn't know BM had their own as well.
6. Re: DPX sequence performance
SteveHoeg Feb 1, 2011 4:42 PM (in response to OneOfTheseWillBeAvailable)The import is multi-threaded but requires relatively little processor power as it is uncompressed anyways. Work went into 5.0.2 to make 2K DPX playback realtime. If that isn't working for you then some part of your system isn't keeping up as lots of others have had success. As DPX is most sensitive to disk speeds that is the obvious answer but it is hard to say.
7. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 1, 2011 5:41 PM (in response to JSS1138)Jim,
V210 is the uncompressed 10-bit YUV version. Aja I think have R10K which I believe avoids the luminance clipping issue endemic to Blackmagic, and a few other technical conveniences. Uncompressed 8-bit formats are well served by preexisting 8-bit fourCCs (HDYC and UYVY for YUV, usually RGBA for RGB).
Steve,
It is not disk speed as other software (including my own code) will happily read and write 1080p24 10-bit RGB DPX files on this system all day long, and at rates always in excess of 40fps. The problem is is not the disks, the problem the way Premiere is trying to read them.
I don't think it's my DPX files either, as Premiere won't even read it's own output (which is not padded to any particular length) at anything other than a crawl.
Could you please find out what if any assumptions are made in the DPX reader with regard to file size, alignment on disk and in memory, disk cluster and block size end-of-image padding and its placement on the various image elements? Also whether this was tested with anything other than 2K, because if the reader relies on alignment and buffering characteristics of a very precise file size, that would also cause breakage.
Something is broke, and I'd like to either fix it my end, help you fix it, or at least have something worthwhile to say to other people when I get asked about this.
P
8. Re: DPX sequence performance
SteveHoeg Feb 1, 2011 5:51 PM (in response to OneOfTheseWillBeAvailable)2K is an approximate upper limit, nothing exclusive. Send me a single one of your DPX files, I will duplicate it and see how well it plays here.
9. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 1, 2011 6:20 PM (in response to SteveHoeg)Hi,
Here you go:
http://www.philrhodes.com/Test0000.dpx
Feel free to try, but the speed issue is the same with DPX that Premiere itself creates, so if there is any problem with the file I don't think it's causing the overarching problem.
P
10. Re: DPX sequence performance
SteveHoeg Feb 3, 2011 7:23 AM (in response to OneOfTheseWillBeAvailable)An image sequence of those will play without dropping frames for me. If you are confident your hardware is fast enough then I'm not really sure what else to suggest.
11. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 6, 2011 10:06 AM (in response to SteveHoeg)I tried putting the disks in RAID-0, just for the sake of a test. This
provided over 1000MB/second of measured throughput, and Premiere did,
finally, managed to play back a 1080p24 10-bit RGB DPX sequence in
realtime.
Remember that I found that other applications which would play DPX in
realtime on the previous disk configuration, which measured about
350-400MB/second. This makes sense, because a 1080p24 RGB 10-bit DPX file,
even if padded to 8MB per frame, requires 192MB/second.
This implies that Premiere's DPX reader is horribly inefficient. It
requires at least twice, and very possibly five times, the amount of
bandwidth that it really should. It reads, at two or three frames per
second, a sequence that my own single-threaded and very naive development
code will read and write at around 40. This is seriously crappy
performance.
On the basis of this I would like to suggest that whatever work was done
on the DPX reader in recent versions is in urgent need of further
refinement. I think users are entitled to assume that a RAID capable of
350-400MB/second is capable of running a 1080p24 10-bit RGB DPX sequence,
and if Adobe want to legitimately advertise that feature, they should
ensure that it can.
P
12. Re: DPX sequence performance
JSS1138 Feb 6, 2011 3:06 PM (in response to OneOfTheseWillBeAvailable) -
13. Re: DPX sequence performance
OneOfTheseWillBeAvailable Feb 6, 2011 4:06 PM (in response to JSS1138)I filed it as a bug earlier.
I think I'm being reasonable. I mean, a 500MB/second RAID that won't run
1080p DPX - but it will run 1080p R210 and R10K AVI files? That's... um...
highly questionable?
P
