1 Reply Latest reply on Feb 2, 2011 3:56 AM by nealeh
    Installing PE9
    MoMo001
      I encountered the following error when installing Premiere Elements 9:
      "The installation process has encountered an error while installing Shared Technologies"
      Can someone helps?
      Lawrence Neo
        • 1. Re: Installing PE9
          nealeh Level 5
          That often means one of two things:
          • You have other Adobe software running background processes (e.g. Adobe Bridge is a common culprit). Identify these in the Processes tab of the Task Manager and end them. If you have other Adobe applications running, close them.
          • You are installing from the incorrect DVD - either trying to install the Mac version on  a PC or vice-versa. Or you are trying to install from the Additional Content DVD before installing the Application.
          Cheers,
          Neale
