First of all, let's agree to speak the same language.
OLH DEVELOPER: The links that you provided in the code
are not for text-only popup windows, they're links to .htm
files for which you've selected "Display in auto-sizing popup"
view. For that issue, I'd verify that the OPT_xxx.htm files you're
calling are actually two directory levels above this topic.
ahlam323: JavaScript has its own special needs when it comes
to syntax, mostly when dealing with unwanted line breaks. This can
happen if you try changing how things are indented when adding
styles such as "<span class=OptPopup>topic</span>". In
addition, you must make sure that you don't remove any of the
JavaScript code that RH places inside the <script> portion of
the <head> section of your topic.
As to the text-only popup, I just switched the primary layout
in a test project to HTML Help, added a popup, viewed it in
preview, generated a .chm output, and viewed the popup in the
output as well. I'm using RH X5.0.2.
Leon
