6 Replies Latest reply: Feb 3, 2011 9:24 AM by meem23 RSS
    Calculation in Exit Event Problem
    meem23 Community Member
      I have a field called lifeCharge and it is calculated from the value of two other fields, allPlans30 or allPlans35. The calculation can only come from one or the other.  I have the default set at zero for allPlans30 and allPlans35. The calculation works fine, however, if I put an amount in field allPlans35 and tab out, it goes to the next field (allPlans30) and resets the amount in allPlans35. How do I prevent this from happening?  Thanks!
      Per Life Charge        $____________
           All Plans ($35 x ________0)
           All Plans ($30 x ________0)
      Script for allPlans35 in the exit event
      if(this.rawValue != 0)
      lifeCharge.rawValue = this.rawValue * 35;
      allPlans30.rawValue = 0;
      Script for allPlans30 in the exit event
      lifeCharge.rawValue = this.rawValue * 30;
      allPlans35.rawValue = 0;
        • 1. Re: Calculation in Exit Event Problem
          I tried another approach - I removed the scripts from allPlans35 and allPlans30 fields and added the following script in the lifeCharge field as a calculation event.
          if
          (allPlans30.rawValue == 0 || allPlans30.rawValue == null)
          this.rawValue
          = allPlans35.rawValue * 35;
          else
          if (allPlans35.rawValue == 0 || allPlans35.rawValue == null)
          this.rawValue
          = allPlans30.rawValue * 30;
          Now what is happening is if you enter an amount in allPlans35 and change your mind and enter an amount in allPlans30, you have to manually delete the amount in allPlans35 to have the calculation work.  Is this the way is has to be or is there a better solution.
          • 2. Re: Calculation in Exit Event Problem
            Niall O'Donovan CommunityMVP
            There are a couple of approaches.
            I am inclined to suggest the following javascript in the calculate event of the lifeCharge object:
            this.rawValue = (allPlans35.rawValue * 35) + (allPlans30.rawValue * 30);
            This is on the basis that the user can only place a value in allPlans35 OR allPlans30.
            To achieve this have the following in the exit events:
            allPlans 35 exit event:
            if (this.rawValue != null) // allPlans35
            allPlans 30 exit event:
            if (this.rawValue != null) // allPlans30
            Hope that helps,
            Niall
            Assure Dynamics
            • 3. Re: Calculation in Exit Event Problem
              Hi Niall,  thanks for your response.  This does work if I mouse exit out of field allPlans35, however, if I keep tabbing it clears them.
              • 4. Re: Calculation in Exit Event Problem
                I am going to suggest a FormCalc script for the two exit events:
                // if this field has a value, then clear the other field
                if (HasValue($) and $ ne 0) then
                endif
                Here is an example:
                https://acrobat.com/#d=sTbpBqlVu6jFqqM7jvRG*A
                Hope that helps,
                Niall
                Assure Dynamics
                • 5. Re: Calculation in Exit Event Problem
                  When I tab out of field allPlans35, it acts very slow and then when I tab out of field allPlans30 I get a Runtime Error and the form closes.
                  • 6. Re: Calculation in Exit Event Problem
                    I think I got it.  I added the following script to the exit event of allPlans30 and allPlans35.
                    if
                    (this.rawValue != 0) //allPlans35
                    xfa.host.resetData("xfa.form.form1.allPlans30");
                    if
                    (this.rawValue != 0)//allPlans30
                    xfa.host.resetData("xfa.form.form1.allPlans35");
