• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
NullPointerException in Network Monitor
Explorer ,
Feb 02, 2011 Feb 02, 2011
After gathering information with Network Monitor in Flash Builder 4 Premium (build 272416) plug-in in Eclipse 3.5.2, NullPointerExceptions are popping up.
Here is an example:
java.lang.NullPointerException
at com.adobe.flexbuilder.monitors.network.store.records.impl.HTTPRecord.getElapsedTime(HTTPRecord.java:246)
at com.adobe.flexbuilder.monitors.network.store.records.impl.NetmonRecordDelegate.getElapsedTime(NetmonRecordDelegate.java:182)
at com.adobe.flexbuilder.monitors.network.view.MasterTableColumnType$6$1.getLabelObject(MasterTableColumnType.java:257)
at com.adobe.flexbuilder.monitors.network.view.MasterTableColumnType$6$1.getLabelText(MasterTableColumnType.java:262)
at com.adobe.flexbuilder.monitors.network.view.MasterTableConfig$MasterTableColumn.getText(MasterTableConfig.java:146)
at com.adobe.flexbuilder.monitors.network.view.MasterTableLabelProvider.getColumnText(MasterTableLabelProvider.java:49)
at org.eclipse.jface.viewers.TableColumnViewerLabelProvider.update(TableColumnViewerLabelProvider.java:70)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:145)
at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(AbstractTableViewer.java:399)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:481)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2111)
at org.eclipse.jface.viewers.AbstractTableViewer.createItem(AbstractTableViewer.java:277)
at org.eclipse.jface.viewers.AbstractTableViewer.add(AbstractTableViewer.java:263)
at org.eclipse.jface.viewers.AbstractTableViewer.add(AbstractTableViewer.java:315)
at com.adobe.flexbuilder.monitors.network.view.MasterTableContentProvider$1.run(MasterTableContentProvider.java:82)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3506)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Often exception details are not recognizable.
After that happens, trying to save into XML doesn't save, though the Save dialog pops up.
Some relieve is possible by closing Network Monitor view and reopening via Window menu helps, otherwise these exceptions make work much less pleasing.
Also double clicking on an NW item to see the source code opens "Loading project...", which spins but does nothing and hangs Eclipse.
Thanks, Andrei.
WinXP SP3, 3GB RAM, Q6600
Message was edited by: kolinitcom
Views
534
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Feb 07, 2011 Feb 07, 2011
Please file a bug for this issue with a sample test case.
Kishan
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Feb 16, 2011 Feb 16, 2011
LATEST
Bug http://bugs.adobe.com/jira/browse/FB-30087 has been filed for this issue.
Votes
Translate
Translate
Report
Report
