1. Re: batch odd dimension images to square
JJMack Feb 2, 2011 9:23 AM (in response to carleq)I have created a script which is a Photoshop Plugin which can be downloaded it is one of my scripts included in my crafting actions package. The Plugin Script name is "AspectRatioSelection.jsx" all you need do is record a two step action that uses it. Step 1 AspectRatioSelection 1:1 centered replace 0 feather. Step 2 menu Image>Image Crop you can batch that action. If you do not want to crop the image you could in the action a new layer fill it with gray then do the selection and delete the square selection to let the image below show through. If you have to add canvas to the short sides as you write you need to write a simple script to add canvas to the short side so both width and height are equal leave the anchor point the center and the have the added canvas color be gray. If you look at some of the simpler scripts in my package I think you will be able to figure out a how to do it. The script will not be hard to write. If you can not figure it out Photoshop ships with a Plugin called the "ScriptListener" this Plug-in is install and uninstalled to have Photoshop record scripts. You can install it start Photoshop create a new document and the add canvas to the document then exit Photoshop. Uninstall the plugin then look on your desktop for you will find two Photoshop scrip files one VSB and one Javascript with two steps new document and add canvas. From the javascript one it should be east to create a javascript function to add canvas. All your script would need to do is find the current document's longest size and use the function to make both the wdith and height this size.. Use one of my simple scripts as a script template. Photoshop also shaips with some scripting guide PDF files.
http://www.mouseprints.net/old/dpr/JJMacksCraftingActions.zip
Contains:
Action Actions Palette Tips.txt
Action Creation Guidelines.txt
Action Dealing with Image Size.txt
Action Enhanced via Scripted Photoshop Functions.txt
CraftedActions.atn Sample Action set includes an example Watermarking action http://www.mouseprints.net/old/dpr/WM900x600.jpg
Sample Actions.txt Photoshop CraftedActions set saved as a text file. This file has some additional comments I inserted describing how the actions work.
12 Scripts for actions
2. Re: batch odd dimension images to square
Michael L Hale Feb 2, 2011 9:12 AM (in response to carleq)If I understand what you want, set the background color to your light grey then run this script with an open document.
var savedRuler= app.preferences.rulerUnits; app.preferences.rulerUnits = Units.PIXELS; var w = app.activeDocument.width; var h = app.activeDocument.height; if(w>h) app.activeDocument.resizeCanvas (w, w, AnchorPosition.MIDDLECENTER); if(w<h) app.activeDocument.resizeCanvas (h, h, AnchorPosition.MIDDLECENTER); //if w==h already square app.preferences.rulerUnits = savedRuler;
You should be able to call the script from an action and batch the action to process all your images at once.
3. Re: batch odd dimension images to square
carleq Feb 2, 2011 9:23 AM (in response to Michael L Hale)Mr Hale
THE ANSWER. Thanks for workflow glue. Looks like this will work, and i'm beginning to understand scripts!
4. Re: batch odd dimension images to square
JJMack Feb 2, 2011 9:28 AM (in response to Michael L Hale)Michael you make it to easy for them how will they ever learn?
5. Re: batch odd dimension images to square
carleq Feb 2, 2011 9:37 AM (in response to JJMack)JJMack,
I could also mark this helpful because laughter is the soul's best medicine!
Honestly, your original message was very resourceful.
6. Re: batch odd dimension images to square
If you want to understand scripts better try these links http://morris-photographics.com/photoshop/tutorials/scripting1.html and http://morris-photographics.com/photoshop/tutorials/scripting2.html I found Trevor Morris. introduction and sample scripts a great starting point. You may also want to look at my crafting actions package you may learns some thing about Actions as well as Scripts you don't know today.
