0 Replies Latest reply on Feb 2, 2011 9:40 AM by stmigs
    Contact Form No Message String
    stmigs
      Hello,
      I have been working with a flash template and have problem with my contact form. I am receiving the form but content does not appear to be posting correctly and I am not getting any information from my message field.
      Here is my formConfiguration.xml (my hosting site said I have to use webformmailer.php or gdform.php instead of contact.php)
      <contactFormConfiguration>
      <emailTo>info@buddyfoto.com</emailTo>
      <serverProcessorType>php</serverProcessorType>
      <serverProcessorFileName>webformmailer</serverProcessorFileName>
      <messageSentText>THANK YOU FOR YOUR MESSAGE.</messageSentText>
      <validateRequiredOnly>true</validateRequiredOnly>
      <submitFormOnEnter>false</submitFormOnEnter>
      <validationMessages>
      <email>This is not a valid e-mail address</email>
      <empty>All required fields must be filled</empty>
      <ntext>This is not a valid text. </ntext>
      <digits>Not valid characters. </digits>
      </validationMessages>
      <exitFullScreenMsg>You have to exit fullscreen mode to use contact form</exitFullScreenMsg>
      <messageSentFailedText>SORRY, YOUR MESSAGE COULDN'T BE SENT</messageSentFailedText>
      <formProcessingText>PROCESSING...</formProcessingText>
      <smtpServer>localhost</smtpServer>
      <smtpPort>25</smtpPort>
      <plainText>true</plainText>
      <emailFromSource>1</emailFromSource>
      <subjectSource>Contact Form from your site</subjectSource>
      </contactFormConfiguration>
      Here is my webformmailer.php
      <?php
      $mail_body = '';
      //-----------------Getting data sent by flash---------------------
      foreach ($_POST as $key => $value){
      if ($key != 'mail_to' && $key != 'smtp_server' && $key != 'smtp_port' &&  $key != 'mail_subject' && $key != 'plain_text'){
      $mail_body .= '<b>'.str_replace('_',' ',$key).'</b>:<br/>';
      $mail_body .= ''.stripslashes($value).'<br/>';
      $message = '<html><body>'.$mail_body.'</body></html>'; //  mail body
      //------------if plain text is set to true removing html tags------
      if ($_POST['plain_text']=='true') {
      $message = str_replace('<br/>',"\r\n", $message);
      $message = strip_tags($message);
      } else {
      //----otherwise composing message headers---------------------------
      $headers  = 'MIME-Version: 1.0' . "\r\n";
      $headers .= 'Content-type: text/html; charset=iso-8859-1' . "\r\n";
      //------------setting conf data-------------------------------------
      $to = $_POST['mail_to'];
      $from = $_POST['mail_from'];
      $subject = $_POST['mail_subject'];
      $smtp_server = $_POST['smtp_server'];
      $smtp_port = $_POST['smtp_port'];
      //---------setting header info--------------------------------------
      $headers .= 'From: ' .$from. "\r\n";
      if (mail($to, $subject, $message, $headers)){ // sending mail
      print('<serverResponse><mail>1</mail></serverResponse>');
      } else {
      print('<serverResponse><mail>0</mail></serverResponse>');
      The hosting site did say that I should use this code for my form but it doesn't work or I don't know how to modify the code
      <form action="/webformmailer.php" method="post">
      <input type="hidden" name="subject" value="Submission" />
      <input type="hidden" name="redirect" value="thankyou.html" />
      First Name: <input type="text" name="FirstName" />
      Last Name :<input type="text" name="LastName" />
      Email: <input type="text" name="email" />
      Comments: <textarea name="comments" cols="40" rows="10">
      Type comments here.</textarea>
      <input type="submit" name="submit" value="submit"/>
      <input type="hidden" name="form_order" value="alpha"/> <input type="hidden" name="form_delivery" value="hourly_digest"/> <input type="hidden" name="form_format" value="html"/> </form>
