4 Replies Latest reply on Feb 2, 2011 10:55 AM by mickna
    Does capturing DV (or HDV) via Firewire a recompression?
      Hi there,
      I am sorry if this was already asked. I did not find a thread...
      If I capture with Premiere a DV tape or a HDV tape via firewire – will it internally “recompressed”? Or is it more a transfer of the data from tape to disk without using a decoder and the data itself is lossless transferred (I do not mean, that DV is lossless - just the transfer from tape to disk)?
      In other words: If I have captured the tape do I have the same data inside premiere (hard drive), as on the tape?
      I'll guess it is just a transfer without decoding and “recoding”.
      If so, the next question would be: Does a new compression occur, if I only use hard cuts? Of course if I change the informations inside a frame (e.g. wipe, color correction, etc.) Premiere has to decode the part and then compress it again. But if there are only hard cuts?
      Thank you,
