2 Replies Latest reply on Feb 4, 2011 5:41 AM by Nikki W
    shrink to fit  need help quick
    Nikki W Level 1
      I have a bunch of forms with a print button, works just great.  However a few people
      have printers that are cutting off the top and bottom and they want the default to be shrink to fit since many of the users of the form are older and can't understand how to change the fit on the print dialogue box.  I found in my Bible a javascr
      ipt but I'm not getting it to work.
      click*
      topmostSubform.Page2.PrintButton1::click - (JavaScript, client)
      this.print ({bShrinkToFit: true});
      I couldn't find where I could control it elsewhere
        • 1. Re: shrink to fit  need help quick
          Kevin Cavallo Level 4
          Maybe this will help (sorry for the lousy formatting).
          print
          Prints a specific number of pages from a document. It is available only for client applications.
          Syntax
          Reference_Syntax
          .print( BOOLEAN param1, INTEGER param2, INTEGER param3, BOOLEAN param4, BOOLEAN param5, BOOLEAN
          param6
          , BOOLEAN param7, BOOLEAN param8 )
          Parameters
          param1
          true | 1 (JavaScript) or 1 (FormCalc) (default)
          Displays a print dialog box and prompts the user for printing setup information and confirmation of the action.
          false | 0 (JavaScript) or 0 (FormCalc)
          Does not display a print dialog box. Printing proceeds without prompting the user for information or confirmation.
          param2
          A valid string representing the page number of the beginning of the range to print. Page values are 0-based, so you represent page 1 with a value of 0.
          The start page is included in the printing.
          param3
          A valid string representing the page number of the end of the range to print. Page values are 0-based, so you represent page 1 with a value of 0.
          The end page is included in the printing.
          param4
          Does not display a cancel dialog box during the printing process.
          Displays a cancel dialog box to stop the printing process.
          param5
          Shrinks the page (if necessary) to fit within the imageable area of the printed page.
          Does not shrink the page to fit within the imageable area of the printed page.
          param6
          Prints each page as an image.
          Prints each page as a page of text.
          param7
          Prints the pages in reverse order.
          Prints the pages in order.
          param8
          Prints all annotations.
          Does not print annotations
          Returns
          Empty
          Applies to
          Version
          XFA 2.1
          Examples
          JavaScript
          xfa.host.print(1, "0", "0", 0, 1, 0, 0, 0);
          FormCalc
          • 2. Re: shrink to fit  need help quick
            Nikki W Level 1
            Thanks Kevin, it worked great.  Only 100 plus forms to change running both through LiveCycle and then opening in Acrobat to extend users rights.
            Nikki
