7 Replies Latest reply on Dec 2, 2011 2:26 PM by megbertapelleid
    Presenter 7 Runtime Error
    FatFreddysCat
      One of my users is getting a continual Runtime Error 2147467259 (80004005) when attempting to use Presenter 7.0.5 with PowerPoint 2007 under Windows 7 (with all the latest critical patches). Uninstalling Presenter (and Acrobat Pro Extended) completely and reinstalling does not fix the problem. The same presentation opens on a Windows XP system with PowerPoint 2007 and Presenter 7.05 without problems.
      Similar problems posted in the forums and elsewhere seem to have no solid resolution.
      Anyone have a fix, or at least suggestions?
      EDIT: Additional information: we completely removed Acrobat Pro 9 Extended and Presenter and installed Acrobat X and Presenter and it does exactly the same thing. Is Presenter just not compatible with Windows 7?
      Thanks in advance.
      Dave Sawyer
        • 1. Re: Presenter 7 Runtime Error
          kristenmzk
          I am having the same issue today - just out of the blue!  Did you receive any responses about your issue?
          • 2. Re: Presenter 7 Runtime Error
            FatFreddysCat Level 1
            None whatsoever. Either very few people are having this issue or many people are but no one has any idea how to fix it. We've basically concluded that Presenter 7 just isn't properly compatible with Windows 7 and are instructing our users who depend on Presenter to downgrade to Windows XP or look for another solution other than Presenter.
            • 3. Re: Presenter 7 Runtime Error
              kristenmzk Level 1
              I have this issue off and on.  Sometimes it just goes away, and sometimes it doesn't.  It prevents me from publishing or using any other Presenter functionality.  I have a hard time believing that no one else has this problem!  Thanks for responding.
              • 4. Re: Presenter 7 Runtime Error
                jpleong
                I don't have this issue, so far, and am running Win 7 64-bit with Office 2007.
                JP
                • 5. Re: Presenter 7 Runtime Error
                  Heyward Drummond Level 3
                  I have not had any problem running Presenter on Windows 7.  I see you tried reinstalling Acrobat and Presenter but did you try uninstalling Powerpoint and then reinstalling? I suspect one of the Microsoft plug-in libraries is corrupt and causing the problem. I've seen problems like this corrected by re-installing Powerpoint.
                  Reminder: Adobe Presenter can only be installed with Powerpoint 2010 32-bit only.  It can be installed in Windows 7 64 bit or 32 bit. Remember....32 bit office only.
                  • 6. Re: Presenter 7 Runtime Error
                    These are all 32-bit systems, and with one it was on an new installation of Office. But that doesn't mean that reinstalling PowerPoint might not help. We'll give that a try and see if it cures the problem.
                    Thanks.
                    • 7. Re: Presenter 7 Runtime Error
                      megbertapelleid
                      I have gotten this error too - running Windows 7, Office 2010 (all installed by my IT department, I have no access to those installers).  New install of Presenter 7.07 after uninstalling previous versions.  Still happening.
                      Try this, as it SEEMS to have worked for me:
                      File > Options > Trust Center > ActiveX Settings
                      Select "Enable all controls without restrictions and without prompting..."
                      So far, working for me... I'll try to come back to this thread and update you if that changes...
