10 Replies Latest reply on Feb 3, 2011 3:52 PM by Flex harUI
    Disallow numbers in textinput while typing
    jmandawg Level 1
      Hi all,
      I'm trying to do something very simple.  When a user types into a text field i want to not allow them to type characters and also to convert lowercase characters to uppercase.
      I tried the following with no success.  I think this should be a pretty simple/common problem.  Hopefully someone can help.
      I put this method into the KEY_DOWN event but it doesn't work.  It goes into the event handler, but doesn't do anything.
      private function txtElementKeyUpHandler(event:KeyboardEvent):void
                  if(event.charCode >= 48 && event.charCode <= 57)
                    event.preventDefault();
                  if(event.charCode >= 97 && event.charCode <= 122)
                      event.charCode -= 32;
        • 1. Re: Disallow numbers in textinput while typing
          jmandawg Level 1
          Sorry, typed it wrong:
          i want to not allow them to type NUMBERS and also to convert lowercase characters to uppercase.
          Also it is in the key down handler:
          private function txtElementKeyDOWNHandler(event:KeyboardEvent):void
          • 2. Re: Disallow numbers in textinput while typing
            Flex harUI Adobe Employee
            TEXT_INPUT event, not KEY_DOWN
            • 3. Re: Disallow numbers in textinput while typing
              FinFlex Level 1
              <mx:TextInput x="585" y="348" restrict="A-Z\\a-z"/>
              Looking for this?
              • 4. Re: Disallow numbers in textinput while typing
                fldev11
                I was just about to add this extremely simple and effective.
                • 5. Re: Disallow numbers in textinput while typing
                  jmandawg Level 1
                  The restrict property is nice, but not powerful enough for what we are ultimately trying to do.
                  This is for a spark TextInput, the textInput (TEXT_INPUT) event does not work as expected.
                  The following will not compile as if the event is not visible:
                                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                      <fx:Script>
                          <![CDATA[
                  protected function onTextInput(event:TextEvent):void
                                  trace("Inside event");
                      </fx:Script>
                      <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                      </fx:Declarations>
                      <s:TextInput id="myTI"  textInput="{onTextInput(event)}" />
                  </s:Application>
                  The following compiles and gets inside the even handler, but the preventDefault() does not work correctly.  No characters should appear in the textinput.
                                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)">
                      <fx:Script>
                          <![CDATA[
                              import mx.events.FlexEvent;
                              protected function application1_creationCompleteHandler(event:FlexEvent):void
                                  myTI.addEventListener(TextEvent.TEXT_INPUT, onTextInput);
                                  //No characters should appear in text field
                      </fx:Script>
                      <fx:Declarations>
                      </fx:Declarations>
                      <s:TextInput id="myTI" />
                  </s:Application>
                  • 6. Re: Disallow numbers in textinput while typing
                    Hmmm.  Looks like we have a bug.  Please file it at bugs.adobe.com/jira.
                    Your second attempt is better, but you will need to use capture phase like
                    this:
                                    myTI.addEventListener(TextEvent.TEXT_INPUT, onTextInput,
                    true);
                    • 7. Re: Disallow numbers in textinput while typing
                      jmandawg Level 1
                      Still not working, this should not accept any characters:
                          <fx:Script>
                              <![CDATA[
                                  import flashx.textLayout.operations.InsertTextOperation;
                                  import spark.events.TextOperationEvent;
                                      myTI.addEventListener(TextEvent.TEXT_INPUT, onTextInput, true);
                          </fx:Script>
                          <fx:Declarations>
                          </fx:Declarations>
                          <s:VGroup>
                          </s:VGroup>
                      </s:Application>
                      • 8. Re: Disallow numbers in textinput while typing
                        This code does not accept characters for me:
                        minHeight="600"
                            <fx:Script>
                                <![CDATA[
                                    protected function
                        true);
                            </fx:Script>
                            <fx:Declarations>
                            </fx:Declarations>
                        </s:Application
                        • 9. Re: Disallow numbers in textinput while typing
                          jmandawg Level 1
                          What build are you running?  I just tested the code on 2 different computers and i can enter text into the textinput.
                          Flash player version:  10,1,102,64 installed
                          Flash Builder Plugin:  v4.0.1 build 277662
                          • 10. Re: Disallow numbers in textinput while typing
                            I am using the Hero preview.  I will try to remember to try it on an older
                            build later.  TEXT_INPUT handling is a feature of the TLF library that is in
                            the SDK.  The player and FlashBuilder version probably don't matter.
