1 Reply Latest reply: Feb 3, 2011 12:23 PM by JSS1138 RSS
    What is best encoding/sizing option?  Premiere Pro/Encore
    zorrocbr Community Member
      I have heard some people say that assets should be encoded before being brought into encore, others say to use dynamic link.  If I am going to go the encode first route, I would do this in Premiere Pro CS5.
      If I am taking a 720 X 540 (1.0)  30.0 fps 48000 hz Mpeg 4 asset and want to convert this to dvd what is the best setting in Premiere Pro?
      Do I create a sequence which is 720 X 480 (0.9091)   29.97    48000 hz and then when exporting use the following settings:
      Format  MPEG 2 DVD
      Preset    Match Source attributes highest quality
      Or do I change this to custom settings:
      Format:  MPEG2
      Preset   Custom
      Change the quality setting to 5
      TV Standard NTSC
      Frame rate   Do I leave it at the default of 29.97 or do I change this to 30?
      Pixel Aspect Ratio- Do I leave this at standard 4:3 (0.909) or change this to square pixels (1.0)?
      Profile and Main do I leave these at the defaults?   Main
      Does it make any difference if the ultimate output will be on a 25 GB blu ray disk?
      Encore CS5
      Premiere Pro CS5
      Quad Core 2.4 GHZ
      6 GB memory
      Windows 7 64 bit
      nvidia geforce 8500
      700Gb free space on hard drive
