1 Reply Latest reply on Feb 3, 2011 8:00 AM by try67
    Possible to do make Batch Sequence Searchable by date?
    haleygurl86 Level 1
      I want to know if it is possible to edit/create new script to Edit Batch Sequence - Searchable, recognize text Using OCR, but to only do it for a date range? How would I go about doing this.
      Right now it takes multiple screens and clicks to make documents searchable, I would like to create a script that tells you the last time you did a batch searchable request, allows you to select a date range, folder would ideally be built in - so I do not have to select it everytime and then on selection of date range, it runs and completes the request. Is this possible? Where do I start?
      haleygurl86
