7 Replies Latest reply on Jul 28, 2011 6:30 AM by Frustrated in AZ
    Literati digital reader problem
    rmm1969
      I have a new Literati . When I down
      loaded two new books to it I get a message "please user your
      adobe id to authorize your ereader to view content
      protected with adobe mobile reader technology" I have both pc a
      nd reader authorized ?
        • 1. Re: Literati digital reader problem
          Aim4lsu04
          I am having the same problem! did you ever get an answer?
          • 2. Re: Literati digital reader problem
            Level 4
            When you activate your Literati with Kobo, you will need to set up an
            account with Kobo.  You may never use it for downloading ebooks, but it's
            required for your Literati to be 'registered'.  You registered with Adobe as
            well, so when you use ADE to connect to the Literati, it will pick up the
            registration and permit you to attach the Literati to ADE so you can
            transfer ebooks.  Here are some items to check:
            You should set up your Literati to access the Kobo bookstore wirelessly.
            That's important because Kobo delivers software updates to your Literati via
            wireless - and you need the latest update so that ADE will work correctly
            with it.
            You need to attach your Literati to your computer first, so it has a chance
            to recognize the Literati and set it up as a USB drive (PC's) or external
            hard drive (Mac's).
            Then, open the ADE application.  It should recognize the Literati in the
            Library pane, on the left hand side.  You can then drag and drop ebooks from
            the right hand pane to the Literati.
            I do it all the time....
            • 3. Re: Literati digital reader problem
              Aim4lsu04 Level 1
              Thank you!!!!
              Amy Howell,  M. Ed.
              8th grade Language Arts
              Gene Pike Middle School
              817.698.1441
              >>> Frustrated in AZ <forums@adobe.com> 4/20/2011 8:46 AM >>>
              with it.
              hard drive (Mac's).
              • 4. Re: Literati digital reader problem
                rizwan.54 Level 1
                In order to fix this you can try following.
                Solution 1) Modify the manifest.xml file located in C:\Usres\Username\My Documents\My Digital Editions:
                1) Quit Digital Editions
                2) Make a backup copy of the manifest.xml (call it something like manifest.good)
                3) Open manifest.xml in notepad
                4) It will appears as one big long line of xml, and you are looking for a tag called  start at the begginning of this
                    and select until you the end of the tag that looks called </de:deviceID>
                5) If you have attached more than one Reader there may be multiple of these.  Delete all of them to make sure.
                6) Save the file (manifest.xml) and quit out of notepad
                7) Ensure you have the Reader plugged in
                8) Launch Digital Editions
                9) The Device Setup Assitant should come up.
                  a) Do NOT click on the "Don't ask again for this device" checkbox.
                  b) Do click on the "Authorize Device" button.
                Solution 2) 1) Open Digital Editions.
                                    2) Connect the Reader and open it.
                                    3) Press the keys Ctrl + Shift + E  on your keyboard.
                                    4) Now unplug the Reader and replug it.
                                    5) There you will find a new drive created similar to C or D drive under "My computer".
                                    6) Open the Readers Drive and you will find one or two folders with name adobe.digital.editions.
                                    7) Delete this folder and plug off and re plug in the Reader.
                                    8) Authorize Reader from the same Adobe ID which you used to Authorize Adobe Digital Editions.
                I hope this will work for you!!!!
                Regards
                Rizwan
                • 5. Re: Literati digital reader problem
                  Iterali
                  My computer runs Windows 7 and doesn't seem to recognize the Literati when I connect it via the USB.  After quite a while it does show up in the directory under My Computer, but it won't access anything.  I've reset both the Literati and the computer, but still doesn't work.  I do have the latest Literati software loaded.  (Note my old computer running Windows ME does recognize the Literati when connected thru the USB and I can see the files.  But I can't activate with that computer -- it's too small and slow to run Adobe Digital.)  Any ideas, anyone?
                  • 6. Re: Literati digital reader problem
                    Cookiewelder
                    I had the same problem.  On ADE they were showing up on my lookbook...but not on the actual lookbook itself.  On your eReader...go to the Documents tab.  The books might be there.  Once you click on them there and they open, they will then show up on your "I'm reading" tab.  Also, depending on what you downloaded, if you click on the information for the book it might say that it is only readable on your computer.  I am not a 'computer' type person...so I found this all out accidentally, ha!
                    • 7. Re: Literati digital reader problem
                      Level 4
                      Part of my frustration is with Microsoft.  Win 7 and XP should work the same
                      way when it comes to handling external devices plugged into a USB port - but
                      sometimes they don't.  This seems to be one of those times....  Your
                      Literati should show up as an external hard drive in Win 7 within moments of
                      being plugged in.  And when you open ADE, it should show the Literati (or
                      any other ereader) almost immediately.  I don't understand the delay you've
                      been experiencing, unless Win 7 or your anti-virus software is doing a full
                      scan on the ereader before it shows you the linkage.
                      If you drag and drop an edocument from ADE to your ereader, its placement on
                      your ereader depends on what kind of edocument it is.  epub's should show up
                      as 'books', while pdf''s should show up as 'documents'.  The Literati is
                      programmed to do that.  ADe doesn't care that much - it lumps them together
                      in the Library.  Cookiewelder hit that nail on the head....
                      Cookiewelder?  I usually eat mine whole.
