6 Replies Latest reply on Feb 3, 2011 1:09 PM by sb25newbie
    Looking for help with javascript to autofill checkboxes based on a numeric value.
    sb25newbie
      I have a numeric field that I would like to have 1 - checkbox
      out of five autofilled based on a numeric value.
      For instance the numeric value is TotalPoints
      If the TotalPoints Value is >10 autofill this checkbox
      If the TotalPoints Value is 10 - 19 autofill this checkbox
      If the TotalPoints Value is 20 - 49 autofill this checkbox
      If the TotalPoints Value is 50 - 69 autofill this checkbox
      If the TotalPoints Value is 70+ autofill this checkbox
      Assistance in writing the correct script for this would be greatly appreciated.
        • 1. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
          George_Johnson MVP & Adobe Community Professional
          You can use a custom Validate script for the text field. Here's one way:
          // Custom Validate script for text field
          (function () {
              //Get this field's value, as a number
              var val = +event.value;
              if (val >= 70) {
                  getField("cb5").value = "exportvalue5";
                  return;
              if (val >= 50) {
                  getField("cb4").value = "exportvalue4";
                  return;
              if (val >= 20) {
                  getField("cb3").value = "exportvalue3";
                  return;
              if (val >= 10) {
                  getField("cb2").value = "exportvalue2";
                  return;
              // <10
                  getField("cb1").value = "exportvalue1";
          Replace "cb1" - "cb5" with the actual names of your check boxes, and "exportvalue1" - "exportvalue5" with their export values that you set up.
          • 2. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
            sb25newbie Level 1
            Thanks for the reply George.  As I said, I'm a newbie to Adobe Acrobat and I must have input something wrong as this did not work.  I did put the validation script in the numeric text field, correct?
            • 3. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
              Do the five check boxes all have the same name, or do they have different names? Can you post a sample form somewhere?
              • 4. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
                sb25newbie Level 1
                All the checkboxes have separate names.
                Check box #1 is AssetClass.0 with the export value of 1
                Check box #2 is AssetClass.1 with the export value of 2
                Check box #3 is AssetClass.2 with the export value of 3
                Check box #4 is AssetClass.3 with the export value of 4
                Check box #5 is AssetClass.4 with the export value of 5
                Score and Strategy
                Use the following calculation to determine your point score and indentify the appropriate strategy listed below.
                A. Add your points for questions 1 – 2.
                B. Add your points for questions 3 – 12.
                C. Subtract B from A. (Numeric Text Box)  name is TotalPoints
                Points Strategy Asset Class Mix (check boxes as named above)
                0 – 10 Primarily Fixed Income: 80% Fixed Income; 20% Equity
                10 – 19 Balanced Fixed Income-Oriented: 60% Fixed Income; 40% Equity
                20 – 49 Balanced Equity-Oriented: 40% Fixed Income; 60% Equity
                50 – 69 Primarily Equity: 20% Fixed Income; 80% Equity
                70+ Equity: 95%; 5% Cash
                • 5. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
                  The following script works for me. Note the addition of the resetForm statement, which I should have included before.
                  (function () {
                      resetForm(["AssetClass"]);
                      if (val >= 70) {
                          getField("AssetClass.0").value = 1;
                          return;
                      if (val >= 50) {
                          getField("AssetClass.1").value = 2;
                          return;
                      if (val >= 20) {
                          getField("AssetClass.2").value = 3;
                          return;
                      if (val >= 10) {
                          getField("AssetClass.3").value = 4;
                          return;
                      // <10
                          getField("AssetClass.4").value = 5;
                  Edit: Yes, placing the code in the Validate event of the text field is correct.
                  • 6. Re: Looking for help with javascript to autofill checkboxes based on a numeric value.
                    sb25newbie Level 1
                    Thank you so much.  I greatly appreciate your help!  It worked and it is totally awesome.
