Hey all, my first post so bear with me, hopefully I can explain what it is I'm trying to do ...
I have an empty mc on the stage called "infoloader" and I'm trying to dynamically load a mc called "my_info0" from the library into the empty "infoloader".
My function references an XML array of thumbnails, which trigger movieclips to load into the FLVPlayback depending on which thumbnail is clicked.
//function to load videos
function callVideo(e:MouseEvent):void{
var video_url = my_images[e.target.name].@VIDEO;
vidplayer.source = video_url;
vidplayer.play();
All is good there.
I also have a mouse over listener to drop info about the video for each thumbnail. (it actually just plays the referenced clip)
//Mouse Over Functions - drops descriptions
function descDrop(e:MouseEvent):void{
var t = "dropVid" + [e.target.name];
this
So far so good.
Using the same concept as the mouse over listener I thought I could load a referenced movie clip from the library, "info0", into my empty movie clip on the stage "infoloader".
//Function to load video info
function callDescription(e:MouseEvent):void{
var d = "info" + [e.target.name];
infoloader.addChild(d);
//trace(d);
No cigar so far.
If I trace "d" I get what I want ... info0 ... but I can't seem to get it to load the "info0" mc into the "infoloader".
I've tried a whack of ideas, but I'm open to any suggestions.
(I want to include buttons in "info0" so I don't want to just add text to my xml file and load that)
This is what I'm looking to accomplish ... http://coleclark-america.com/sn2010.asp
This is last years version and doesn't use xml, but had a whole lotta repeated code, just trying to expedite.
Hopefuly there's enough code here, if not, let me know.
Thanks in advance,
Ter
This line...
is creating a string. A string is not a display object. You mentioned something about it being a library object. Is that the class name that you have assigned to the object in the library (not its library name)?
Hey Ned,
Thanks for the quick response.
Yes, that's the class name I've given it (it's also the object name).
I'm assuming I need to somehow convert the string "info0" to reference the object but not sure how.
I notice if I create a var in my function ...
var my_info0:MovieClip = new info0();
//var d = "info" + [e.target.name];
infoloader.addChild(my_info0);
//trace(d);
It loads as expected.
To use a String to dynamically create a class instance, you need to use something like the following...
var ClassRef:Class = Class(getDefinitionByName("className")); // your string in place of className
var classInstance:* = new ClassRef();
addChild(classInstance);
Hmmm, over my head but I get the concept.
If I add your code ...
var ClassRef:Class = Class(getDefinitionByName("d"));
infoloader.addChild(classInstance);
I get ...
Error #1065: Variable d is not defined.
at global/flash.utils::getDefinitionByName()
If I comment out var d and replace d in the next line with "info0" it loads fine.
var ClassRef:Class = Class(getDefinitionByName("info0"));
Yep, you put quotes around strings and you don't put quotes around variables that have string values.
var ClassRef:Class = Class(getDefinitionByName(d));
Ned ... You are the MAN!!
Thanks, that did it.
I thought it was strange that it had quotes, but yours had it so I had it, meant to try a test removing the quotes but forgot.
In case anyone else has this problem ...
Now I just have to do a little research to understand "why" it works.
Thanks again.
Ter
You're welcome Ter.
