1. Re: [CS4 Win] Weird 'Bug' giving overset text in duplicate object - stumped!
P Spier Feb 3, 2011 2:54 PM (in response to Skempy)Hi Simon.
My initial reaction was it might have to do with the third party plugins, but I exported to .inx to strip them out, and then NONE of the frames had both words. I also thought it might be that the the frame isn't a right triangle and the slight angles on the vertical and horizontal might be a problem, but I made a new frame with the same hypotenuse but the correct legs, and that didn't make a difference, either. (I made it by drawing a rectangular frame exactly half as high as it was wide, adding a point at the center of the top path segment with the pen, then deleted the two upper corner points).
I have to say my conclusion is that the problem here is there really isn't enough room in the frame for both words with that inset. Adding 3% to the size of the frame (by clicking the chainlink to link changes to height and width, then typing +3% after the height [adding in the scale fields scales the type, too, so don't do it there] and pressing Enter) brings both words into view.
Curiously, When I opened the file in CS5, the words fit without messing around. Cutting and pasting the frames with overset made both words appear. This could be due to the new way ID deals with text in non-rectangular shapes. When I opened the .inx file without the plugin information in CS5 all the text was visible in all frames. I think the only reason the text ever fit in the original CS4 file might have to do with one of the plugins, but that's pure speculation. I don't think there's any sort of bug here.
