Hello Everyone!
In Captivate 5 (CP5), I've got the Progress indicator turned on in the Quiz. I want to enlarge the font of the indicator, but when I do, the size of the box cuts off the text. Part of the text is not displayed, or is shoved onto a new line. (This looks really bad with my design.) So how can I make that progress indicator box larger?
See, I'd really LOVE to have that all on one line....
This is SO simple that I HAVE to be missing something.
Please tell me what it is.
Thank you for your excellent assistance in advance!
Greg
Select the Progress Indicator, hold down the ALT key, and use the arrow keys on your keyboard to make the bounding box bigger.
Once you have one in the correct location and size, apply this to all the others.
Does this work for you?
Hello,
Alternative for Rod's solution with shortcut keys (ALT in combi with right arrow for 1 pixel increment, or ALT-SHIFT-Right for 10px increment): change size in the Size&Position accordion of the Properties panel. Since you will only change the width, be sure to deselect 'Constrain proportions'. Use the small curved arrow in the top right of this accordion to apply to all items of same style (beware: not only size but position will be applied too).
Lilybiri
Hi RodWard, Lilybiri, as at Captivate 8.0.1.242 any changes I make to the width of the Progress Indicator aren't maintained. So when I widen the indicator, go to another slide and come back, the width has been reset.
I've tried making this change in the question master slide, but the same thing happens.
Any ideas on this would be greatly appreciated
