5 Replies Latest reply on Aug 14, 2006 8:56 AM by microes
    motion sequence
    microes
      _
        • 1. Re: motion sequence
          Level 7
          microes,
          > when would you use a looping array to create a motion
          > sequence when would use otherwise to create a sequence.
          > how would it be written?
          The answer(s) to your question depend(s) on the definition of the words
          you're using. Let's break it down ...
          > sequence
          Not sure what you mean by "looping array." I think you're asking, "When
          would I loop through an array to create a motion sequence?" If that's it,
          my answer would be, "When you want to handle a motion sequence that requires
          the programmatic animation of several movie clips at once.
          The wording of this one confuses me a bit. I think you're asking, "When
          would I use an different approach -- not looping through an array, but
          something else -- to create a sequence?" If that's it ... well, that's such
          a broad question, I might answer, "When you don't necessarily want to handle
          a motion sequence that requires the programmatic animation of several movie
          clips at once."
          As for how it would be written, that depends on plenty, plenty, plenty
          more detail.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. motion sequence
            microes Level 1
            _
            • 3. Re: motion sequence
              microes Level 1
              i.ve been using onMotionFinished.
              i just wanted to know how else would a animation be programmed where one mc occurs after the other.
              what would be another approach?
              • 4. Re: motion sequence
                Level 7
                microes,
                > well my thinking is to use onMotionFinished.
                That's an event of the Tween class. The Tween class is one of many ways
                to programmatically animate movie clips.
                I'm sure there are as many ways as a programmer can imagine. ;) It
                depends on what you're trying to accomplish, microes.
                David Stiller
                • 5. Re: motion sequence
                  microes Level 1
                  thank you
