15 Replies Latest reply on Feb 6, 2011 3:55 AM by Pablo Souza
    Value Objects not accessible
    bspShankar Level 1
      I am new to flex and have problem in accessing value objects.
      1. a video plays
      2. on completion of video display login page comes up
      3. On click of signin button i am stroing it in value objects through modellocator.
      ModelLocator
      package model
          import vo.LoginVO;
          [Bindable]
          public class ModelLocator
              private static var instance:ModelLocator=null;
              public static function getInstance():ModelLocator
                  if (instance == null)
                      instance=new ModelLocator();
                  return instance;
              public function ModelLocator()
                  if (instance != null)
                      throw new Error("Cannot Create Instance Of Singleton Class ModelLocator");
                  instance=this;
                  initModels();
              /*---------------------------------- VO Variables Declaration------------------- */
              public var login:LoginVO;
              /* -------------------------- VARIABLES INITIALIZATION-------------------------- */
              public function initModels():void
      //value objects
      package vo
          [Bindable]
          public class LoginVO
              public var _username:String;
              public var _password:String;
              public function LoginVO()
              public function get username():String
                  return _username;
              public function set username(value:String):void
                  _username = value;
              public function get password():String
                  return _password;
              public function set password(value:String):void
                  _password=value;
      <s:states>
              <s:State name="State1"/>
              <s:State name="Carousel"/>
              <s:State name="LoginView"/>
              <s:State name="dispaly"/>
              <s:State name="test"/>
          </s:states>
          <local:Carousel includeIn="Carousel" />
          <Components:LoginView includeIn="LoginView" loginClickEvent="loginview1_loginClickEventHandler(event)"/>
          <Components:dispaly  includeIn="dispaly" clickEvent="currentState='test';"/>
          <Components:test includeIn="test"/>
          <mx:Canvas width="100%" height="100%" horizontalScrollPolicy="off" backgroundColor="#000000"
                     verticalScrollPolicy="off" includeIn="State1" >
              <mx:VideoDisplay id="videoDisplay" complete="currentState='LoginView';"       //
                               source="assets/AppFlv/NewFlutteringFlag.flv" x="410" y="179" />
          </mx:Canvas>
        • 1. Re: Value Objects not accessible
          bspShankar Level 1
          sorry i could not put my problem completely...
          cont..
          As mentioned above i have stored the value objectson click of of signin
          var loginvo:LoginVO=new LoginVO();
          loginvo.username=event.userName;
          loginvo.password=event.password;
          And i want to access username in other mxml page
          But iam not can please give me an hint
          Thanks and Regards
          • 2. Re: Value Objects not accessible
            Pablo Souza Level 3
            Are you having problems to populate your value object LoginVO?
            Please, send us more information.
            Regards,
            Pablo Souza
            • 3. Re: Value Objects not accessible
              Pablo Souza Level 3
              I got your problem now!
              You can have access to it through the ModelLocator instance.
              ModelLocator.getInstance()..loginVO._username;
              ModelLocator.getInstance()..loginVO._password;
              The ModelLocator is a implementation of the Singleton pattern, so that you assure you have just one instance of the ModelLocator class.
              You also have defined the getInstance() method as an static function. It allows you to retrieve an unique instance of the ModelLocator class from everywhere.
              Hope it helps you!
              Best regards,
              Pablo Souza
              • 4. Re: Value Objects not accessible
                bspShankar Level 1
                thanks for ur reply
                I have used it as below as u told.....
                <mx:VBox>
                        <s:Label text="Username"/>
                        <s:TextInput id="user" text="{modelLocator.login._username}"/>
                        <s:Label text="Password"/>
                        <s:TextInput id="pass" text="{modelLocator.login._password}"/>
                </mx:VBox>
                I am getting the following error
                but also iam not accessible
                i.e the text input is empty...
                pls guide me
                thanks & regards
                • 5. Re: Value Objects not accessible
                  bspShankar Level 1
                  i.e i used
                  <mx:VBox>
                      </mx:VBox>
                  • 6. Re: Value Objects not accessible
                    Pablo Souza Level 3
                    As I told you the getInstance() method is returning the ModelLocator instance and it's an static method.
                    In order to retrieve the ModelLocator instance, you must call this static method and just after that you can have access to all your public variables.
                    <mx:VBox>
                            <s:TextInput id="user" text="{ModelLocator.getInstance().login._username}"/>
                            <s:TextInput id="pass" text="{ModelLocator.getInstance().login._password}"/>
                    </mx:VBox>
                    I could see you were trying to get access to ModelLocator instance through a variable called modelLocator.
                    To do that you must have something like:
                    private var modelLocator:ModelLocator = ModelLocator.getInstance();
                    Let mew know if you need more information.
                    Regards,
                    Pablo Souza
                    • 7. Re: Value Objects not accessible
                      bspShankar Level 1
                      yes i have used that in the below fashion
                      [Bindable]
                                  public var modelLocator:ModelLocator=ModelLocator.getInstance();
                      But also not able to access
                      • 8. Re: Value Objects not accessible
                        bspShankar Level 1
                        Is there any problem in populating the vo
                        i have populated in the below fashion on click of sigin btn.
                        Pls let me know if any mistake i have done
                        Thanks & regards
                        • 9. Re: Value Objects not accessible
                          Pablo Souza Level 3
                          How did u assigned the username into login variable in ModelLocator class?
                          You have sent this code:
                          After this lines, have you assigned the variable loginvo to the login variable in the ModelLocator class?
                          ModelLocator.getInstance().login = loginvo;
                          Regards,
                          Pablo Souza
                          • 10. Re: Value Objects not accessible
                            Pablo Souza Level 3
                            And also you don't need to create a new instance of loginVO.
                            You can assign that directly just like below:
                            ModelLocator.getInstance().login._username = event.userName;
                            ModelLocator.getInstance().login._password = event.password;
                            Regards,
                            Pablo Souza
                            • 11. Re: Value Objects not accessible
                              bspShankar Level 1
                              Thank u so much for ur support.....
                              Now its  working fine....
                              With Regards
                              • 12. Re: Value Objects not accessible
                                bspShankar Level 1
                                Yeah Hi,...
                                if iam using the below way it works fine
                                                currentState="dispaly";
                                But if i use  it directly like below i get error
                                ModelLocator.getInstance().login.username = event.userName;
                                                ModelLocator.getInstance().login.password = event.password;
                                error
                                TypeError: Error #1009: Cannot access a property or method of a null object reference.
                                    at NeuronLogitech_Lawpad/loginview1_loginClickEventHandler()[C:\Documents and Settings\xp\Adobe Flash Builder 4 Plug-in\NeuronLogitech_Lawpad\src\NeuronLogitech_Lawpad.mxml:26]
                                    at NeuronLogitech_Lawpad/___NeuronLogitech_Lawpad_LoginView1_loginClickEvent()[C:\Documents and Settings\xp\Adobe Flash Builder 4 Plug-in\NeuronLogitech_Lawpad\src\NeuronLogitech_Lawpad.mxml:45]
                                    at flash.events::EventDispatcher/dispatchEventFunction()
                                    at flash.events::EventDispatcher/dispatchEvent()
                                    at mx.core::UIComponent/dispatchEvent()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\co re\UIComponent.as:12266]
                                    at Components::LoginView/doLogin()[C:\Documents and Settings\xp\Adobe Flash Builder 4 Plug-in\NeuronLogitech_Lawpad\src\Components\LoginView.mxml:25]
                                    at Components::LoginView/__btnLogin_click()[C:\Documents and Settings\xp\Adobe Flash Builder 4 Plug-in\NeuronLogitech_Lawpad\src\Components\LoginView.mxml:56]
                                I just wanted why the second solution does not work in flex4
                                • 13. Re: Value Objects not accessible
                                  Pablo Souza Level 3
                                  That's because the loginVO instance is null inside the ModelLocator.
                                  If you wanna use this approache, initialize the login variable inside ModelLocator:
                                  public var login:LoginVO = new LoginVO();
                                  Regards,
                                  Pablo Souza
                                  • 14. Re: Value Objects not accessible
                                    bspShankar Level 1
                                    It worked fine......
                                    But i have doubt abt using getters and setters with value objects.....
                                    Is it necessary  to use it on client side........how beneficiary is it...
                                    Thanks & Regards
                                    • 15. Re: Value Objects not accessible
                                      Pablo Souza Level 3
                                      ActionScript supports properties, so usually you shouldn't ever need to declare it unless you are doing something out of the ordinary as trigger associated events, calculate a return value or wants to make it possible to override properties that are inherited from a superclass.
                                      Best regards,
                                      Pablo Souza
