• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
I can't change tools.. Please help! :(
Guest
Feb 04, 2011 Feb 04, 2011
i cant change all my tools...i cant change direct selection tool,line segment tool and exc.. please help me pleaseeeeeeee....
İ vvant to dravv circle (oval). For this i must change "Rectangle tool" ..BUt i cant change it..
Views
67.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
New Here , Jan 13, 2014 Jan 13, 2014
I've had this same problem. The only way i've been able to work around it is by holding down the Alt key, then clicking the tool button (any of them).
Hope this helps.
Votes
Translate
Translate
New Here , Jul 20, 2015 Jul 20, 2015
Absoutely, I solve the problem(It is not problem)
Maybe you click the Rectangle tool shortly then It is not change!!
If you want change the other tools, you have to click the Rectangle tool(current selected tool) over 1 second.
then you will find another tool(circle, star, etc...)
Votes
Translate
Translate
Adobe
Community Expert ,
Ma-riza,
When you Click and Hold, hovering over the Rectangle Tool, the underlying tools should fly out. Do they (not)?
Votes
Translate
Translate
Report
Report
Guest
they dont
Votes
Translate
Translate
Report
Report
New Here ,
Mar 26, 2018 Mar 26, 2018
worked like a charm....thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
If you hit "L" the keyboard shortcut, does the tool switch?
Do you have any plug ins, especially the ones that add extra tools.
Try resettting your preferences. Cmd-Opt-Ctrl-Shift when restarting AI on a Mac or Alt-Crtl-Shift on a PC to reset to the defaults.
Votes
Translate
Translate
Report
Report
Engaged ,
Jun 23, 2011 Jun 23, 2011
I just started having this problem, too. The "fly-out" menus no longer work in CS5 Illustrator or Photoshop. I am able to cycle through the available tools if I hold the Option key while clicking on a tool. The "L" key does switch back to the previous tool. I have rebuilt my user preferences, restarted, repair permissions. Any suggestions on what else to look at?
Votes
Translate
Translate
Report
Report
New Here ,
Hope this helps.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 06, 2021 Oct 06, 2021
Bless your soul this is the only thing that worked for me!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 11, 2022 Mar 11, 2022
Thank you!  I was having the same issue and it was driving me crazy!!
Votes
Translate
Translate
Report
Report
New Here ,
Jul 21, 2022 Jul 21, 2022
OMG THANK YOU!!!!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 21, 2022 Sep 21, 2022
that worked - but why?!
Votes
Translate
Translate
Report
Report
Participant ,
Feb 12, 2015 Feb 12, 2015
Found it. I have a MacBook Pro with a 17-inch display on the left and a Visio 1080P on the right, via HDMI.  If my displays are set up like this, things are okay:
But if they are set up like this
then two things happen. One is that the fly-out tools don't fly out, and the other is that I can't drag an object above the left (MacBook's) top menu bar. The reason I changed to the bottom arrangement is I preferred the way my pointer moved smoothly between monitors. !
Votes
Translate
Translate
Report
Report
Community Beginner ,
Jun 16, 2015 Jun 16, 2015
I found the solution to this issue. Its got something to do with the monitor. When I movie AI to my other monitor the flyouts work normally (by holding down the left mouse button). They also work normally when I don't have the window set to full screen.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 30, 2015 Jun 30, 2015
This holds true here too. The flyouts do not work on my secondary monitor but do work on my main laptop screen.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 23, 2016 Jun 23, 2016
Yeah! It worked. It's a bug, Adobe didn't fixed the problem yet 😕
Votes
Translate
Translate
Report
Report
New Here ,
Go to which tool you need it and hold on the tool until it's flyout
Regards,,,
Votes
Translate
Translate
Report
Report
New Here ,
Jan 16, 2017 Jan 16, 2017
Confirming this, although I find the 4 seconds that it has to be held in ps cc 2017 annoyingly long and unproductive.
As for tool switching between subtools, I thought "L" was not working to switch between Lasso, Polygonic Lasso, and Magnetic Lasso until I discovered the Tools preference to use Shift to switch. Once I un-checked that, pressing L worked (as would presumably Shift-L if you don't un-check it).
Votes
Translate
Translate
Report
Report
New Here ,
Votes
Translate
Translate
Report
Report
New Here ,
Jun 09, 2016 Jun 09, 2016
it's work with thanks
Votes
Translate
Translate
Report
Report
New Here ,
Apr 19, 2023 Apr 19, 2023
LATEST
Thank you so much! This was super helpful.
Votes
Translate
Translate
Report
Report
Sep 17, 2015 Sep 17, 2015
This is still occurring, even on PC. I discovered that if I have illustrator open on my secondary monitor, the tools don't work as they should (same problem mentioned here). If you drag illustrator on to your main screen it's fine.
As far as changing screen positions, it doesn't seem to have any effect in Windows 8.1, the app has to be placed on the primary display. Sort of annoying, but not a train smash.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 05, 2016 Dec 05, 2016
yes work for me ps 2017
Votes
Translate
Translate
Report
Report
