1 Reply Latest reply on Feb 23, 2011 6:08 AM by nimazz
    How to export as PDF with Duotone?
    nimazz
      In my indesign script, I am trying to export the indd as PDF while reserving the duotone.
      When I tried with Adobe Indesign. (File -> export with default settings) it worked fine. I checked with the “output preview” in acrobat reader pro. It works fine.
      But when I tried to do it in indesign scripting as give below. I don’t get the duotone preserved. When I monitor with “output preview” it’s CMYK.
      Any advice will be helpful.
      with(app.pdfExportPreferences)
                  bleedBottom = myDocument.documentPreferences.documentBleedBottomOffset+5;
                  bleedTop = myDocument.documentPreferences.documentBleedTopOffset+5;
                  bleedInside = myDocument.documentPreferences.documentBleedInsideOrLeftOffset+5;
                  bleedOutside = myDocument.documentPreferences.documentBleedOutsideOrRightOffset+5;
                  cropMarks = true;
                  registrationMarks = true;
                  acrobatCompatibility=AcrobatCompatibility.acrobat4
              //myDocument.exportFile(ExportFormat.pdfType, new File(filename+".pdf"));
              myDocument.exportFile(ExportFormat.pdfType, new File("/c/duotone.pdf"));
        • 1. Re: How to export as PDF with Duotone?
          nimazz Level 1
          I found the solution to this. I make the below changes and it worked. If you find the same issue with duotone, try this out.
                      cropMarks = true;
                       includeICCProfiles = false;
                      acrobatCompatibility=AcrobatCompatibility.acrobat6
                      standardsCompliance = PDFXStandards.pdfx42007Standard;
          Hope someone will find this helpful.
          Regards
