10 Replies Latest reply on Feb 6, 2011 8:58 AM by kglad
    tracking of movieclip
    forsakenedsj
      Hello, im doing a FlashLite 2.1, now have following code.
      stop();
      fscommand2 ("SetSoftKeys", "", "Quit Game");
      Key.removeListener (myListener);
      var myListener:Object = new Object ();
      myListener.onKeyDown = function ()
          var keyCode = Key.getCode ();
          if (keyCode == ExtendedKey.SOFT2)
              gotoAndStop("Quit");
      Key.addListener (myListener);
      // on load red turn
      turn = "red";
      buildboard();
      var ball:Number;
      // set focus on redzone_mc's s_1
      // user only can navigate on redzone only not blue. up down only.
      if (turn == "red")
          Selection.setFocus(s_1);
          s_7.enabled = false;
          s_8.enabled = false;
          s_9.enabled = false;
          s_10.enabled = false;
          s_11.enabled = false;
          s_12.enabled = false;
      else if (turn == "blue")
          Selection.setFocus(s_7);
          s_1.enabled = false;
          s_2.enabled = false;
          s_3.enabled = false;
          s_4.enabled = false;
          s_5.enabled = false;
          s_6.enabled = false;
      //onLoad 3 marbles each
      function buildboard ()
          _root.ballred.gotoAndStop("0b");
          _root.ballblue.gotoAndStop("0b");
          _root.container.gotoAndStop("0b");
          _root.ball1.gotoAndStop("3b");
          _root.ball2.gotoAndStop("3b");
          _root.ball3.gotoAndStop("3b");
          _root.ball4.gotoAndStop("3b");
          _root.ball5.gotoAndStop("3b");
          _root.ball6.gotoAndStop("3b");
          _root.ball7.gotoAndStop("3b");
          _root.ball8.gotoAndStop("3b");
          _root.ball9.gotoAndStop("3b");
          _root.ball10.gotoAndStop("3b");
          _root.ball11.gotoAndStop("3b");
          _root.ball12.gotoAndStop("3b");
      i'm doing a game called Mancala (Cong kak).
      // ball1 - ball12 all are movieclips which has at least 36 marbles inside. so onLoad, i make all movieclip stop at "3b", which is labelled. now I need to do the following sequence.
      Example. inside ball1 got 3 balls, click ball1, become 0 ball, it will go to ball2 and drop 1 ball, den go to ball3 to drop 1 ball, den go to ball4 to drop 1 ball...
      have done this following code:
      bowl1.onPress = function()
          selectedItem = this;
          _root.ball1.gotoAndStop("0b");
          _root.ball2.gotoAndStop("4b");
          _root.ball3.gotoAndStop("4b");
          _root.ball4.gotoAndStop("4b");
          turn = "blue";
      but i cant be doing this for all 12 movieclips so have source for help and did this:
      var bowlList:Array = [ball1,ball2,ball3,ball4,ball5,ball6,ball7,
                            ball8,ball9,ball10,ball11,ball12];
      function movestones(bowlIndex)
          var numStones = bowlList[bowlIndex]._currentframe-1;
          for (;numStones>0;numStones--)
              //place stone
      s_1.onPress = function()
          movestones(0);
      but have no idea wd to do for //place stone.. anyone could help me? thanks lot!
        • 1. Re: tracking of movieclip
          i don't understand:
          • 2. Re: tracking of movieclip
            forsakenedsj Level 1
            Erm, there's a game called Mancala, or cong kak.
            onLoad the board will appear 3 marbles each.
            [12] [11] [10] [09] [08] [07]
            [01] [02] [03] [04] [05] [06]
            and assume above is the board, is red's turn. so navigation at [01]. user can navigate up or down key to select which one to "pick" up and "throw" to other holes in anticlockwise direction.
            Example:
            - user click [01], inside [01] become 0 marble, so user have 3 marbles to put at [02][03][04], one each.  [02][03][04] have 4 each after throwing
            - user click [02], inside [02] become 0 marble, so user have 3 marbles to put at [03][04][05], one each. [03][04][05] have 4 each after throwing
            the code i did so far helps to track the last ball, but doesn't do the adding stone effect...
            • 3. Re: tracking of movieclip
              stop();
              // on load red turn
              turn = "red";
              buildboard();
              var ball:Number;
              if (turn == "red")
                  turn = "blue";
                  for (var i=numStones;i>0;i--)
              bowlList[bowlIndex].prevFrame();
              nextIndex=bowlIndex+i;
              if(nextIndex>12){
              nextIndex=nextIndex%12;
              bowlList[(nextIndex)].nextFrame();
                  movestones(0);
              • 4. Re: tracking of movieclip
                Hey, it really works what I wanted =) thanks!
                But now you see I have turns: red and blue.
                so the phone onLoad is turn = "red" which as stated in my coding in my post.
                +++ [12] [11] [10] [09] [08] [07] <---- B +++
                +B+                                                  +R+
                +++ [01] [02] [03] [04] [05] [06] <---- R +++
                Legend: B = blue, R = red
                so now is scenario:
                - red's turn, navigations at the red side, if last ball reach its own "home", user will have free turn. if not is blue's turn.
                - blue's turn, navigations at the blue side, if last ball reach its own "home", user will have free turn, if not is red's turn.
                P.S.: both "home" has its own movieclips: blue = ballblue_mc, red = ballred_mc
                How can i do that? I have tried using turn = "red"; on top, and tried it before using my old code but doesn't work..
                if possible can do this additional scenario:
                - red's turn, if [05] or any [..] inside has alot of marbles example got 9 marbles, it will still put marbles at [06], "home", [07], [08], [09], [10], [11], [12], [01]
                // meaning skipping blue's "home".
                - blue turn same...
                • 5. Re: tracking of movieclip
                  your game is going to get more complicated to encode, especially because of the way you've set it up.  anyway, i don't see any easy way to proceed from where you are and i don't see any easy way to help you without doing all the coding myself.
                  • 6. Re: tracking of movieclip
                    oh.. yea I find it very complicated too, thats why source for help =\
                    but is it possible just to add on the turns from the code that u modified? like after last ball den its other turn?
                    • 7. Re: tracking of movieclip
                      sure.  at the end of the code i suggested (or anywhere you want to toggle the turn variable), you can use:
                      if(turn=="red"){
                      turn="blue";
                      } else {
                      turn="red";
                      • 8. Re: tracking of movieclip
                        Hmmm.. it doesn't work. The blue's navigation never shows up at other side after i click any [..] on the red's side... anyways forgot to tell you that ball1 to ball12 are movieclips, below them are buttons so I can call the moveStone function onPress..
                        Is it something affecting it from changing?
                        Cause the button's state OVER is a picture of my navigation
                        • 9. Re: tracking of movieclip
                          the code i suggested works.  it will toggle the turn variable.  whether that does what you want is a different issue.  you need to do something with that variable to see an on-stage change.
                          • 10. Re: tracking of movieclip
                            declared turn as String? have tried using _root.turn but error =\
                            var turn:String;
                            turn = "red";
                            if (turn == "red")
                            turn = "blue";
                            else
                            turn = "red";
