3 Replies Latest reply on Feb 6, 2011 9:09 PM by BhaskerChari
    text input help
    fldev11
      Hello just a quick question,
      Basically I have a textbox named username and what I I'd like to do is display the the words "username" inside the textbox in faded out text until the user clicks that textbox where the textbox will turn blank, and again if for example the user was to navigate else where outside the textbox I'd like "username" text to return inside the textbox.
      Thanks.
        • 1. Re: text input help
          fldev11 Level 1
          Still can't seem to figure it out, if anyone's got any idea it would be a great help.
          • 2. Re: text input help
            Pablo Souza Level 3
            It seems you are lokking for something like this:
            http://cookbooks.adobe.com/post_Spark_TextInput_with_Caption__Watermark_-18408.html
            Best regards,
            Pablo Souza
            • 3. Re: text input help
              BhaskerChari Level 4
              Hi fldev11,
              Check out the Prompting TextInput component from the FlexLibs Library. You can include an as file PromptingTextInput.as file and simply use the component..
              http://code.google.com/p/flexlib/wiki/ComponentList
              I am also pasting the source of the class for your convenience..
              Copyright (c) 2007 FlexLib Contributors.  See:
                  http://code.google.com/p/flexlib/wiki/ProjectContributors
              Permission is hereby granted, free of charge, to any person obtaining a copy of
              this software and associated documentation files (the "Software"), to deal in
              the Software without restriction, including without limitation the rights to
              use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
              of the Software, and to permit persons to whom the Software is furnished to do
              so, subject to the following conditions:
              The above copyright notice and this permission notice shall be included in all
              copies or substantial portions of the Software.
              THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
              IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
              FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
              AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
              LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
              OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
              SOFTWARE.
              package com.view.components.login
              import flash.events.Event;
              import flash.events.FocusEvent;
              import flash.text.TextField;
              import mx.controls.TextInput;
              import mx.events.FlexEvent;
              * The <code>PromptingTextInput</code> component is a small enhancement to
              * standard <code>TextInput</code>.  It adds the ability to specify a prompt
              * value that displays when the text is empty, similar to how the prompt
              * property of the <code>ComboBox</code> behaves when there is no selected value.
              public class PromptingTextInput extends TextInput
                      /** Flag to indicate if the text is empty or not */
                      private var _textEmpty:Boolean;
                       * Flag to prevent us from re-inserting the prompt if the text is cleared
                       * while the component still has focus.
                      private var _currentlyFocused:Boolean = false;
                       * Constructor
                      public function PromptingTextInput()
                              _textEmpty = true;
                              addEventListener( Event.CHANGE, handleChange );
                              addEventListener( FocusEvent.FOCUS_IN, handleFocusIn );
                              addEventListener( FocusEvent.FOCUS_OUT, handleFocusOut );
                      //      prompt
                      /** Storage for the prompt property */
                      private var _prompt:String = "";
                       * The string to use as the prompt value
                      public function get prompt():String
                              return _prompt;
                      [Bindable]
                      public function set prompt( value:String ):void
                              _prompt = value;
                              invalidateProperties();
                      //      promptFormat
                      /** Storage for the promptFormat property */
                      private var _promptFormat:String = '<font color="#999999"><i>[prompt]</i></font>';
                       * A format string to specify how the prompt is displayed.  This is typically
                       * an HTML string that can set the font color and style.  Use <code>[prompt]</code>
                       * within the string as a replacement token that will be replaced with the actual
                       * prompt text.
                        * The default value is "&lt;font color="#999999"&gt;&lt;i&gt;[prompt]&lt;/i&gt;&lt;/font&gt;"
                       public function get promptFormat():String
                               return _promptFormat;
                       public function set promptFormat( value:String ):void
                               _promptFormat = value;
                               // Check to see if the replacement code is found in the new format string
                               if ( _promptFormat.indexOf( "[prompt]" ) < 0 )
                                       // TODO: Log error with the logging framework, or just use trace?
                                       //trace( "PromptingTextInput warning: prompt format does not contain [prompt] replacement code." );
                               invalidateDisplayList();
                       //      text
                        * Override the behavior of text so that it doesn't take into account
                        * the prompt.  If the prompt is displaying, the text is just an empty
                        * string.
                       [Bindable("textChanged")]
                   [CollapseWhiteSpace]
                   [NonCommittingChangeEvent("change")]
                       override public function set text( value:String ):void
                               // changed the test to also test for null values, not just 0 length
                               // if we were passed undefined or null then the zero length test would
                               // still return false. - Doug McCune
                               _textEmpty = (!value) || value.length == 0;
                               super.text = value;
                       override public function get text():String
                               // If the text has changed
                               if ( _textEmpty )
                                       // Skip the prompt text value
                                       return "";
                               else
                                       return super.text;
                        * We store a local copy of displayAsPassword. We need to keep this so that we can
                        * change it to false if we're showing the prompt. Then we change it back (if it was
                        * set to true) once we're no longer showing the prompt.
                       private var _displayAsPassword:Boolean = false;
                       override public function set displayAsPassword(value:Boolean):void {
                               _displayAsPassword = value;
                               super.displayAsPassword = value;
                       override public function get displayAsPassword():Boolean {
                               return _displayAsPassword;
                       //      overriden methods
                        * @private
                        * Determines if the prompt needs to be displayed.
                       override protected function updateDisplayList( unscaledWidth:Number, unscaledHeight:Number ):void
                               // If the text is empty and a prompt value is set and the
                               // component does not currently have focus, then the component
                               // needs to display the prompt
                               if ( _textEmpty && _prompt != "" && !_currentlyFocused )
                                       if ( _promptFormat == "" )
                                               super.text = _prompt;
                                       else
                                               super.htmlText = _promptFormat.replace( /\[prompt\]/g, _prompt );
                                       if(super.displayAsPassword) {
                                               //If we're showing the prompt and we have displayAsPassword set then
                                               //we need to set it to false while the prompt is showing.
                                               var oldVal:Boolean = _displayAsPassword;
                                               super.displayAsPassword = false;
                                               _displayAsPassword = oldVal;
                               else {
                                       if(super.displayAsPassword != _displayAsPassword) {
                                               super.displayAsPassword = _displayAsPassword;
                               super.updateDisplayList( unscaledWidth, unscaledHeight );
                       //      event handlers
                        * @private
                       protected function handleChange( event:Event ):void
                               _textEmpty = super.text.length == 0;
                        * @private
                        * When the component recevies focus, check to see if the prompt
                        * needs to be cleared or not.
                       protected function handleFocusIn( event:FocusEvent ):void
                               _currentlyFocused = true;
                               // If the text is empty, clear the prompt
                               if ( _textEmpty )
                                       super.htmlText = "";
                                       // KLUDGE: Have to validate now to avoid a bug where the format
                                       // gets "stuck" even though the text gets cleared.
                                       validateNow();
                        * @private
                        * When the component loses focus, check to see if the prompt needs
                        * to be displayed or not.
                       protected function handleFocusOut( event:FocusEvent ):void
                               _currentlyFocused = false;
                               // If the text is empty, put the prompt back
              } // end class
              } // end package
              Bhasker
