6 Replies Latest reply: Feb 6, 2011 7:24 PM by Joe Riggs RSS
    Ripple delete and audio/video tracks
    Joe Riggs Community Member
      Hello,
      1. When I edit I tend to cherboard the audio/video, so I'll have one shot Video/Audio 1 and the next on Video/Audio 2. Now unfortunately when I ripple delete, the clips will overlap. What I want them to do is line up with the last clip no matter what video/audio track it is (see pic). I hope this is just some settings I need to change.
      2. Once a clip is in the timeline, let's say on Video/Audio 1 and I'd like to bring the clip to video/audio 2, is it possible to drag it and have both the audio and video move to their track 2's? Right now I have to move the audio and video separately even if they are linked.
      3. Is there a shortcut for unlocking (seperating audio/video) clips?
        • 1. Re: Ripple delete and audio/video tracks
          JSS1138 CommunityMVP
          1.  Ripple won't work.  You'll have to drag them all over.  Hit A on the keyboard, then Shift click the first clip.  This will allow you to select the entire group of clips and drag them over without disturbing the clip's alignment.
          2.  No, and for good reason.  If something was already on a track, it would get overwritten.  This is why you have to do it manually.
          3.  Alt before clicking will perform a temporary unlink.  Release the Alt key, and the clips are linked again.
          • 2. Re: Ripple delete and audio/video tracks
            Harm Millaard CommunityMVP
            Jim was faster.
            • 3. Re: Ripple delete and audio/video tracks
              Ann Bens CommunityMVP
              2. In previous versions (Pro2?) the audio part went automaticly to the corresponding track.
              Select clip and drag the video part to track two.
              Don't let go of the clip.
              Now press Shift and hold down, still with the clip selected.
              Move the mouse to audio track 2. (or whichever track you want it to be on)
              You can do this with multiple clips selected and the other way around starting with the audio part selected first.
              • 4. Re: Ripple delete and audio/video tracks
                Regarding ripple delete that is really disappointing.  I now have to make 3 moves to achieve what I want, including manually dragging clips to make them align...yikes! I hope Adobe can make some option in the future, where it is more akin to FCP,  select + delete and they align at the tail of the previous clip regardless of track.
                Thanks Jim and Ann for #2 and  #3.
                • 5. Re: Ripple delete and audio/video tracks
                  The easy solution for now would be to just not stagger your clips.  Keep them all on the same track.  Only add clips to higher tracks if you need them to overlap.
                  • 6. Re: Ripple delete and audio/video tracks
                    Yeah, I will probably butt the clips up against each other and use ALt + the rolling edit tool. However, there are other advantages in staggering your clips by character or angle whether you plan to overlap or not, such as it's easier to read the timeline and It facilitates audio and color correction.
