2 Replies Latest reply on Feb 7, 2011 5:29 AM by Black Dragan
    Indesign CS4 SDK Programming
    Black Dragan
      Hai Everyone,
        I am doing a script in Indesign CS4 in JavaScript.  I need to send data between javascript and C++ dll.  can I do this using Ext Object Lib ?
      Thanks & Regards,
      Black Dragan...
        • 1. Re: Indesign CS4 SDK Programming
          Harbs. Level 6
          Itmight be possible to use External Object, but I'm not sure that's the best way to go about what you are after. Depending on what you are trying to do, including scripting support in a plugin might be the way to go...
          I'd ask this on the SDK forum. You'll probably get better asnwers there.
          Harbs
          • 2. Re: Indesign CS4 SDK Programming
            Black Dragan Level 1
            Hi Harbs,
              Actually I am Using Extend Script Tool Kit SDK. i am able to communicate and transfer the data from extend Script to C++ dll by creating an instance of external lib.  is there any way to communicate or send data from c++ to script withpout any request from script ?
            Thanks & Regards,
            Black Dragan...
