4 Replies Latest reply on Feb 7, 2011 11:00 AM by Pablo Souza
    Hi.  complete newbie here.
    olddummy Level 1
      trying to use a value stored in a variable as a link to an image.
      image soure = "../asset/mypic.jpg"  works but
      var mypic:String = "../asset/mypic.jpg"
      image source = mypic
      or
      image source = "mypic"
      doesn't, should it?
        • 1. Re: Hi.  complete newbie here.
          Pablo Souza
          There are a lot of ways to do that:
          You can specify the image source:
          <mx:Image source="mypic.jpg"/>
          <mx:Image source="@Embed(source='mypic.jpg')"/>
          <mx:Image source="@Embed(source='assets/mypic.jpg')"/>
          <mx:Image id="image1"/>
          Or you can set the image source at runtime:
          // Retrieve the image
          private function getImage():void
              var imageSource:String = "../asset/mypic.jpg"
              image1.load(imageSource);
          Or also you can embed the image:
          [Embed(source="mypic.gif")]
          [Bindable]
          public var imgClass:Class;
          <mx:Image source="{imgClass}"/>
          Best regards,
          Pablo Souza
          • 2. Re: Hi.  complete newbie here.
            baldoldkp
            Pablo hi. thanks for your response.
            past.load(ResourceManager.number1); this loads an mx image with a picture which is defined in the ResourceManager.as file it works
            past.load(cardaddress); doesn't but cardaddress holds ResourceManager.number1 (i put a trace on it and it definitely holds this value)
            past.source =
            "../assets/Ace of hearts";  this works reading the picture direct from the folder that it is in.
            past.source ="(cardaddress)"
            past.source ="{cardaddress}"
            past.source ="cardaddress" doesn't
            so whenever i hold the address value in a variable it all fails, surely i should be able to.
            Sorry i am sure i am being obtuse but i have a lot of pictures and wish to address them by building a variable string.
            cheers
            • 3. Re: Hi.  complete newbie here.
              baldoldkp Level 1
              my apologies again.
              image.load(variable) works.!!
              many many thanks
              • 4. Re: Hi.  complete newbie here.
                Pablo Souza Level 3
                Nice it works!
                Best regards,
                Pablo Souza
