0 Replies Latest reply on Feb 7, 2011 10:22 AM by TᴀW
    CS4 vs CS5 compatibility issue with columns[0]
    TᴀW Adobe Community Professional & MVP
      Hello,
      I've run into a problem.
      I have a CS4 script that has this line:
      myLines = myTextFrame.columns[0].lines.everyItem();
      This gave me a simple way to access all lines in a text frame that are on the edge of the frame, and ignore any lines in columns.
      In CS5, if a paragraph in a text frame has span columns on, then columns[0] only returns the lines until the first span paragraph.
      In other words: myTextFrame.columns.length in CS4 would return 1 if there are no columns.
      But in CS5, if there are no columns but one of the paragraphs is split into 2, myTextFrame.columns.length returns 4.
      Given this, the question is: Is there a quick way to get all lines in a textframe that are in the leftmost column in CS5?
      Thank you,
      Ariel
