• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
'Use minimum version required by the Flex SDK' setting question
New Here ,
Feb 07, 2011 Feb 07, 2011
Can someone explain why after downloading the latest stable Hero SDK (build 19786), which only has fp10.2 support in the framwork/libs/player directory, would the 'Use minimum version required by the Flex SDK' build property still tell Flash Builder to build for fp10.1?
In my flex-config.xml file from this new SDK, I see the target-player attribute is set to 10.2. Is there a bug in burrito that would fail for that value to be used?
Views
1.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Feb 10, 2011 Feb 10, 2011
LATEST
No. That should work. Builder also reads the minimum value from flex-config.xml.
Just to check - you added this as a new SDK in Preferences -> Flash Builder -> Installed Flex SDKs and either made that the default SDK or changed the project to use the new SDK, right?
Votes
Translate
Translate
Report
Report
