• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
FlashHelp_Pro Output in Mozilla FireFox face problems
New Here ,
Feb 08, 2011 Feb 08, 2011
I have prepared a Flash Help using the 'Slate-Vertical' skin. When I generate the output in Interner Explorer, it works fine. But when I try to open in FireFox, it shows a the following message saying to change the Global settings. I have added the location of the Flash Help but still it shows the same error and open with only the body page, the top page which has content, search, index, and glossary pane are missing.
What should I do to correct this.
Views
849
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 08, 2011 Feb 08, 2011
See if Snippet 106 on my site helps.
@petergrainge
Votes
Translate
Translate
Community Expert ,
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Hi Peter,
Thanks, it works fine. But when I search by entreing the key work using the Search option, it lists topics of the key word but when I click the topic, the page is not displayed. But it works fine with IE.
Votes
Translate
Translate
Report
Report
Community Expert ,
Your first post suggested the help didn't even open. Are you saying that you have followed the steps in Rick's demo and now it opens but with a problem when you search?
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Yes I have followed the Rick demo and everything works fine except the Search option.
Votes
Translate
Translate
Report
Report
Community Expert ,
I don't work with FlashHelp or WebHelp Pro so I cannot help you on that. I suggest using one of the supplied sample projects and generating from there. That will at least tell you whether it is a general problem with your setup or a project specific problem.
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi folks
I suppose the larger question here is to ask if you are also using the RoboHelp Server component? If not, there is no need for the "Pro" output and it may well explain why things are wonky.
We see more than a few folks that choose the "Pro" outputs in the misguided belief that they offer something more or better than the basic WebHelp or FlashHelp outputs offer. But the fact is, they are simply outputs that have been specifically coded to work with the additional and separately installed and managed RoboHelp Server component.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Captiv8. I understand now about 'PRO' helps. Now I have generated a Flash Help, it works fine with IE and FireFox, but in Google Chrome it displays a balnk page.
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 10, 2011 Feb 10, 2011
LATEST
Local files of Webhelp or FlashHelp cannot be viewed in Chrome due to handling of security issues through Google Chrome. The FlashHelp pro or WebHelp pro will be shown correctly when viewed in Google Chrome through help hosted on Server.
If you want to view local FlashHelp in Google Chrome you may follow the steps as below after closing all instances of Google Chrome:
1. Go to Command line through Start->Run->cmd
2. Go to the install path of Google Chrome on your machine. In general it is the local user application path like C:\Users\<yourusername>\AppData\Local\Google\Chrome\Application\chrome.exe
3. For going to the install path you may type cd C:\Users\<yourusername>\AppData\Local\Google\Chrome\Application\ on the command line window
4. Now launch Google Chrome by typing chrome.exe --allow-file-access-from-files
5. Type the address of the help in the browser window and you should be able to see the local help
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
