2 Replies Latest reply on Feb 8, 2011 4:44 AM by ledroff
    [svn:cairngorm3:] 20188: Migrating the todo sample to flex-mojos 4 (you' ll have to migrate to maven3 as well)
    ledroff Adobe Employee
      Revision: 20188
      Revision: 20188
      Author:   ledroff@adobe.com
      Date:     2011-02-08 00:25:14 -0800 (Tue, 08 Feb 2011)
      Log Message:
      Migrating the todo sample to flex-mojos 4 (you'll have to migrate to maven3 as well)
      This change was tested with maven 3.0.2.
      No more problem of blank/empty screen with this sdk : 4.5.0.18623.
      In addition, there is one JAR (AIR development tools) that is packaged with the Flex SDK but is not open source.
      Because of this, flexMojos cannot host this artifact. To build from source, you will need to install this artifact into your own private repo:
      >mvn install:install-file -DgroupId=com.adobe.flex -DartifactId=adt -Dversion=4.5.0.18623 -Dpackaging=jar -Dfile=adt.jar
      This JAR is bundled with the Flex SDK, which is freely available from Adobe?\226?\128?\153s website:
      http://opensource.adobe.com/wiki/display/flexsdk/Downloads
      Modified Paths:
          cairngorm3/trunk/samples/todo/pom.xml
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_android/.actionScriptProperties
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_shell/.actionScriptProperties
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_shell/pom.xml
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_test/.actionScriptProperties
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_todolist/.actionScriptProperties
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_todolist/pom.xml
