0 Replies Latest reply on Feb 8, 2011 2:08 AM by Bhushan Phalak
    Scroll BOX item when collapse the Panel.
    Bhushan Phalak
      I have added multipal collapse panel in tha box item.
      ------------------------------------ collapsePanel.as ---------------------
      package control {
          import flash.events.*;
          import mx.effects.AnimateProperty;
          import mx.events.*;
          import mx.containers.Panel;
          import mx.core.ScrollPolicy;
           * The icon designating a "closed" state
          [Style(name="closedIcon", property="closedIcon", type="Object")]
           * The icon designating an "open" state
          [Style(name="openIcon", property="openIcon", type="Object")]
           * This is a Panel that can be collapsed and expanded by clicking on the header.
          public class CollapsiblePanel extends Panel {
              private var _creationComplete:Boolean = false;
              private var _open:Boolean = true;
              private var _openAnim:AnimateProperty;
              public var scrollFn:Function = emptyCall ;
               * Constructor
              public function CollapsiblePanel(aOpen:Boolean = true):void
                  super();
                  open = aOpen;
                  this.addEventListener(FlexEvent.CREATION_COMPLETE, creationCompleteHandler);
              // BEGIN: event handlers                ------------------------------------------------------------
              private function creationCompleteHandler(event:FlexEvent):void
                  this.horizontalScrollPolicy = ScrollPolicy.OFF;
                  this.verticalScrollPolicy = ScrollPolicy.OFF;
                  _openAnim = new AnimateProperty(this);
                  _openAnim.duration = 300;
                  _openAnim.property = "height";
                  titleBar.addEventListener(MouseEvent.CLICK, headerClickHandler);
                  _creationComplete = true;
              private function headerClickHandler(event:MouseEvent):void { toggleOpen(); }
              private function callUpdateOpenOnCreationComplete(event:FlexEvent):void { updateOpen(); }
              // --end--: event handlers            - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
              // BEGIN: private methods                ------------------------------------------------------------
              // sets the height of the component without animation, based
              // on the _open variable
              private function updateOpen():void
                  if (!_open) height = closedHeight;
                  else height = openHeight;
                  setTitleIcon();
              // the height that the component should be when open
              private function get openHeight():Number {
                  return measuredHeight;
              // the height that the component should be when closed
              private function get closedHeight():Number {
                  var hh:Number = getStyle("headerHeight");
                  if (hh <= 0 || isNaN(hh)) hh = titleBar.height;
                  return hh;
              // sets the correct title icon
              private function setTitleIcon():void
                  if (!_open) this.titleIcon = getStyle("closedIcon");
                  else this.titleIcon = getStyle("openIcon");
              // --end--: private methods            - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
              // BEGIN: public methods                ------------------------------------------------------------
               * Collapses / expands this block (with animation)
              public function toggleOpen():void
                  if (_creationComplete && !_openAnim.isPlaying) {
                      _openAnim.fromValue = _openAnim.target.height;
                      if (!_open) {
                          _openAnim.toValue = openHeight;
                          _open = true;
                          dispatchEvent(new Event(Event.OPEN));
                      }else{
                          _openAnim.toValue = _openAnim.target.closedHeight;
                          _open = false;
                          dispatchEvent(new Event(Event.CLOSE));
                      setTitleIcon();
                      _openAnim.play();
                      scrollFn();//This function will take the section to top
               * Empty call
              public function emptyCall():void
                  //empty call
               * Whether the block is in a expanded (open) state or not
              public function get open():Boolean {
                  return _open;
               * @private
              public function set open(aValue:Boolean):void {
                  _open = aValue;
                  if (_creationComplete) updateOpen();
                  else this.addEventListener(FlexEvent.CREATION_COMPLETE, callUpdateOpenOnCreationComplete, false, 0, true);
               * @private
              override public function invalidateSize():void {
                  super.invalidateSize();
                      if (_open && !_openAnim.isPlaying) this.height = openHeight;
              // --end--: public methods            - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
      How to scrolling the box automatically and set panel on the top when click on panel.
