1. Re: ACR won't save files other than in original file folder.
Fred K. Feb 8, 2011 11:34 AM (in response to gingerdee1)Hi Gingerdee1,
Yes strange ....
-Do you have the right privelige to save at an other location..... >>privelige-user .... or..... >>folder-protection (read-only)... >> or network privelige changed
-Is that disc full maybe at that location....
-Do you try to save a file with illegal characters in the file name...-Working with other RAW-files.............
-Did you change any other situation....than before...Regards Fred K
2. Re: ACR won't save files other than in original file folder.
gingerdee1 Feb 8, 2011 11:45 AM (in response to Fred K.)Thanks Fred. No to all. The only thing is I had someone recently install 4
more gigs of memory on my machine because the 4 I had was running CS5
sluggishly. Something may have happened there. I'm beginning to think my
only alternative is to uninstall and then reinstall. Thanks for answering.
Ginny D
3. Re: ACR won't save files other than in original file folder.
PECourtejoie Feb 8, 2011 12:06 PM (in response to gingerdee1)Hello!
Uninstall/reinstall are seldom a good solution. Resetting the preferences usually works.
4. Re: ACR won't save files other than in original file folder.
Fred K. Feb 8, 2011 12:02 PM (in response to gingerdee1)Hi Gingerdee1,
Did you change the memory usage for PhotoShop in the preference menu.....
Maybe that is not the main solution but........
....re-instal...... than you will NOT know the problem!!!!! ... better first search !!
Other wise .... I can not help you.......maybe someone else...
Fred
