5 Replies Latest reply on Feb 9, 2011 2:50 AM by Flex Rock
    Loading controls in Repeater
    Flex Rock Level 1
              I have a repeater in which i have Label and HRule. The length of dataprovider is 4. So label and Hrule appears four times. But i need the Hrule to be appeared only three times.
      example.
      I need the layout to be like this.
      Regards,
      Jayagopal.
        • 1. Re: Loading controls in Repeater
          BhaskerChari Level 4
          Hi Jayagopal,
          Try this code..
          <?xml version="1.0"?>
          <!-- charts/UsingBarSets.mxml -->
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
            <mx:Script><![CDATA[
               import mx.collections.ArrayCollection;
               [Bindable]
               private var _dataProvider:ArrayCollection = new ArrayCollection([
                           {label:"Video Quality Optimized (recommended)"},
                           {label:"480p (High)"},
                           {label:"360p (Med)"},
                           {label:"288p (Low)"}
            ]]></mx:Script>
          <mx:VBox verticalGap="0" width="300" backgroundColor="#000000">
            <mx:Repeater id="rptComp" dataProvider="{_dataProvider}" recycleChildren="true">
             <mx:Label text="{rptComp.currentItem.label}" color="white" fontSize="13" />
             <mx:HRule width="100%" strokeColor="white" visible="{rptComp.currentIndex != _dataProvider.length-1}" includeInLayout="{rptComp.currentIndex != _dataProvider.length-1}" />
            </mx:Repeater>
          </mx:VBox>
          </mx:Application>
          Bhasker Chari
          Message was edited by: BhaskerChari
          • 2. Re: Loading controls in Repeater
            Flex Rock Level 1
            Thanks Bhasker, this is what i am expecting.
            thanks,
            Jayagopal.
            • 3. Re: Loading controls in Repeater
              Flex Rock Level 1
              Hi Bhasker,
                                   I need another one thing. I need to set the selected value that is the default selected value.
              thanks,
              Jayagopal.
              • 4. Re: Loading controls in Repeater
                @Jayagopal,
                Where do you want the selected value..??
                There is no such a property for Repeater comp..Can you please elaborate your question..??
                Bhasker
                • 5. Re: Loading controls in Repeater
                  Flex Rock Level 1
                  Hi Bhasker,
                                       Refer the image. I need to higlight the same way it was highlighted in the image.
                  thanks,
                  Jayagopal.
