2 Replies Latest reply on May 18, 2011 10:33 AM by bkrajendra
    Air Auto Update Error -- Flash Builder Burrito.
    jeffcg2 Level 1
      This is my first attempt at this, so I may be missing something simple.
      I'm not having any luck getting an Air app to automatically update.
      If I manually go to  http://localhost/air1/air1.air and redownload the file I will get a popup that asks if I want to update the app, but when I say ok I get this error.
      "There was an error checking for updates. Error# 16816"
      I haven't found a reason yet,
      Any ideas?
      update.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <update xmlns="http://ns.adobe.com/air/framework/update/description/2.5">
        <version>2.0</version>
        <url>http://localhost/air1/air1.air</url>
        <description>1.0 - First version</description>
      </update>
      file -- air1.mxml
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             applicationComplete="init()">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import air.update.events.UpdateEvent;
                  import air.update.ApplicationUpdaterUI;
                  import mx.controls.Alert;
                  protected var appUpdater:ApplicationUpdaterUI = new ApplicationUpdaterUI(); // Used for auto-update
                  protected function init():void
                      // Check for update
                      this.checkUpdate();
                      Alert.show("checking update");
                  // This function is triggered when the application finished loading.
                  // Initialize appUpdater and set some properties
                  protected function checkUpdate():void
                      // set the URL for the update.xml file
                      appUpdater.updateURL = "http://localhost/air1/update.xml";
                      appUpdater.addEventListener(UpdateEvent.INITIALIZED, onUpdate);
                      appUpdater.addEventListener(ErrorEvent.ERROR, onUpdaterError);
                      // Hide the dialog asking for permission for checking for a new update.
                      // If you want to see it just leave the default value (or set true).
                      appUpdater.isCheckForUpdateVisible = true;
                      appUpdater.initialize();
                  // Handler function triggered by the ApplicationUpdater.initialize.
                  // The updater was initialized and it is ready to take commands.
                  protected function onUpdate(event:UpdateEvent):void
                      // start the process of checking for a new update and to install
                      appUpdater.checkNow();
                  // Handler function for error events triggered by the ApplicationUpdater.initialize
                  protected function onUpdaterError(event:ErrorEvent):void
                      Alert.show(event.toString());
          </fx:Script>
          <s:Button x="47" y="55" label="Button"/>
          <mx:ColorPicker x="61" y="119"/>
          <s:ComboBox x="77" y="216"/>
          <s:ComboBox x="77" y="185"/>
          <s:ComboBox x="77" y="154"/>
      </s:WindowedApplication>
      file  -- air1-app.xml
      <?xml version="1.0" encoding="utf-8" standalone="no"?>
      <application xmlns="http://ns.adobe.com/air/application/2.5">
      <!-- Adobe AIR Application Descriptor File Template.
          Specifies parameters for identifying, installing, and launching AIR applications.
          xmlns - The Adobe AIR namespace: http://ns.adobe.com/air/application/2.5
                  The last segment of the namespace specifies the version
                  of the AIR runtime required for this application to run.
          minimumPatchLevel - The minimum patch level of the AIR runtime required to run
                  the application. Optional.
          <!-- A universally unique application identifier. Must be unique across all AIR applications.
          Using a reverse DNS-style name as the id is recommended. (Eg. com.example.ExampleApplication.) Required. -->
          <id>air1</id>
          <!-- Used as the filename for the application. Required. -->
          <filename>air1</filename>
          <!-- The name that is displayed in the AIR application installer.
          May have multiple values for each language. See samples or xsd schema file. Optional. -->
          <name>air1</name>
           <!-- A string value of the format  <0-999>.<0-999>.<0-999> that represents application  version which can be used to check for application upgrade.
          Values can also be 1-part or 2-part. It is not necessary to have a 3-part value.
           An updated version of application must have a versionNumber value  higher than the previous version. Required for namespace >= 2.5 .  -->
          <versionNumber>2.0.0</versionNumber>
           <!-- A string value (such as "v1", "2.5", or "Alpha 1") that  represents the version of the application, as it should be shown to  users. Optional. -->
          <!-- <versionLabel></versionLabel> -->
          <!-- Description, displayed in the AIR application installer.
          <!-- <description></description> -->
          <!-- Copyright information. Optional -->
          <!-- <copyright></copyright> -->
          <!-- Publisher ID. Used if you're updating an application created prior to 1.5.3 -->
          <!-- <publisherID></publisherID> -->
          <!-- Settings for the application's initial window. Required. -->
          <initialWindow>
              <!-- The main SWF or HTML file of the application. Required. -->
              <!-- Note: In Flash Builder, the SWF reference is set automatically. -->
              <content>[This value will be overwritten by Flash Builder in the output app.xml]</content>
              <!-- The title of the main window. Optional. -->
              <!-- <title></title> -->
              <!-- The type of system chrome to use (either "standard" or "none"). Optional. Default standard. -->
              <!-- <systemChrome></systemChrome> -->
              <!-- Whether the window is transparent. Only applicable when systemChrome is none. Optional. Default false. -->
              <!-- <transparent></transparent> -->
              <!-- Whether the window is initially visible. Optional. Default false. -->
              <!-- <visible></visible> -->
              <!-- Whether the user can minimize the window. Optional. Default true. -->
              <!-- <minimizable></minimizable> -->
              <!-- Whether the user can maximize the window. Optional. Default true. -->
              <!-- <maximizable></maximizable> -->
              <!-- Whether the user can resize the window. Optional. Default true. -->
              <!-- <resizable></resizable> -->
              <!-- The window's initial width in pixels. Optional. -->
              <!-- <width></width> -->
              <!-- The window's initial height in pixels. Optional. -->
              <!-- <height></height> -->
              <!-- The window's initial x position. Optional. -->
              <!-- <x></x> -->
              <!-- The window's initial y position. Optional. -->
              <!-- <y></y> -->
              <!-- The window's minimum size, specified as a width/height pair in pixels, such as "400 200". Optional. -->
              <!-- <minSize></minSize> -->
               <!-- The window's initial maximum size, specified as a width/height  pair in pixels, such as "1600 1200". Optional. -->
              <!-- <maxSize></maxSize> -->
          <autoOrients>false</autoOrients>
          <fullScreen>false</fullScreen>
          <visible>false</visible>
        </initialWindow>
          <!-- We recommend omitting the supportedProfiles element, -->
          <!-- which in turn permits your application to be deployed to all -->
          <!-- devices supported by AIR. If you wish to restrict deployment -->
          <!-- (i.e., to only mobile devices) then add this element and list -->
          <!-- only the profiles which your application does support. -->
          <!-- <supportedProfiles>desktop extendedDesktop mobileDevice extendedMobileDevice</supportedProfiles> -->
          <!-- The subpath of the standard default installation location to use. Optional. -->
          <!-- <installFolder></installFolder> -->
          <!-- The subpath of the Programs menu to use. (Ignored on operating systems without a Programs menu.) Optional. -->
          <!-- <programMenuFolder></programMenuFolder> -->
          <!-- The icon the system uses for the application. For at least one resolution,
          specify the path to a PNG file included in the AIR package. Optional. -->
          <!-- <icon>
              <image16x16></image16x16>
              <image32x32></image32x32>
              <image36x36></image36x36>
              <image48x48></image48x48>
              <image72x72></image72x72>
              <image128x128></image128x128>
          </icon> -->
          <!-- Whether the application handles the update when a user double-clicks an update version
          of the AIR file (true), or the default AIR application installer handles the update (false).
          <!-- <customUpdateUI></customUpdateUI> -->
          <!-- Whether the application can be launched when the user clicks a link in a web browser.
          <!-- <allowBrowserInvocation></allowBrowserInvocation> -->
          <!-- Listing of file types for which the application can register. Optional. -->
          <!-- <fileTypes> -->
              <!-- Defines one file type. Optional. -->
              <!-- <fileType> -->
                  <!-- The name that the system displays for the registered file type. Required. -->
                  <!-- <name></name> -->
                  <!-- The extension to register. Required. -->
                  <!-- <extension></extension> -->
                  <!-- The description of the file type. Optional. -->
                  <!-- The MIME content type. -->
                  <!-- <contentType></contentType> -->
                  <!-- The icon to display for the file type. Optional. -->
                  <!-- <icon>
                  </icon> -->
              <!-- </fileType> -->
          <!-- </fileTypes> -->
          <!-- Specify Android specific tags that get passed to AndroidManifest.xml file. -->
          <!--<android>
              <manifestAdditions>
              <![CDATA[
                  <manifest android:installLocation="auto">
                      <uses-permission android:name="android.permission.INTERNET"/>
                      <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
                      <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
                      <uses-configuration android:reqFiveWayNav="true"/>
                      <supports-screens android:normalScreens="true"/>
                      <uses-feature android:required="true" android:name="android.hardware.touchscreen.multitouch"/>
                      <application android:enabled="true">
                          <activity android:excludeFromRecents="false">
                              <intent-filter>
                                  <action android:name="android.intent.action.MAIN"/>
                                  <category android:name="android.intent.category.LAUNCHER"/>
                              </intent-filter>
                          </activity>
                      </application>
                  </manifest>
              </manifestAdditions>
          </android> -->
          <!-- End of the schema for adding the android specific tags in AndroidManifest.xml file -->
      </application>
