1 Reply Latest reply on Jun 21, 2007 1:58 PM by WebmastaDj
    MovieClip Problem
    WebmastaDj
      Ok, not sure if this is the right category for this post or not. But here is the problem; I will try to describe it as best I can.
      I need to get this problem fixed. Basically, I have a movie (aka MainMovie) with a MovieClip (SubMovie) in the libary. Once the MainMovie gets to a certain frame, it stops. Than frame I have dropped in the SubMovie. Although the MainMovie has stopped, the SubMovie needs to play and run actionscript within itself (while the MainMovie stays stopped/paused). I have tried this and I am not having much luck.
      Is there something I can do in Actionscript to do this? I know about the flash.display.MovieClip property. I have tried just using the following code within the SubMovie inorder to stop, start, and jump frames ONLY in the SubMovie; MainMovie staying still. In the libary properties for the SubMovie, I "Export for Actionscript"
      But of course, that doesn't work. Any Ideas?
      FYI: Using Flash CS3
