7 Replies Latest reply on Feb 9, 2011 3:42 AM by nealeh
    Burning a DVD with Premiere Elements 8
    acslater1969
      I am attempting to burn a dvd with premiere elements 8 and i am having trouble.  When I get done editting my video I go to the share tab.  From the share tab I select the dvd burner and then click "burn".  It looks like it is burning just fine and i don't get any error messages.  When it is done it ejects the disc, and says that it is done.  The problem is that the discs don't play on my computer like a dvd.  I thought that the process seemed striaght forward, but i can't figure out my mistake.
        • 1. Re: Burning a DVD with Premiere Elements 8
          the_wine_snob Level 9
          Can you give us the details of your Project, including the source footage used?
          What brand of blank media are you using?
          As a test, can you choose Burn to Folder, which will create the VIDEO_TS folder, where you locate it, with the necessary IFO, BUP and VOB files inside. Then, point your DVD software player to the VIDEO_TS folder, as see if that plays. Please report on this test.
          • 2. Re: Burning a DVD with Premiere Elements 8
            acslater1969 Level 1
            the source footage is a .mpg that I created in premiere.  I am using memorex brand dvds.  the VIDEO_TS folder is located on the dvd.  I just got the dvd to play on my computers alternate dvd player (PowerDVD DX), but my default dvd player (Windows Media Center) still doesn't recognize it.  The issue is that I am sending this video to a customer and I would like to make sure that it plays on thier default player.
            • 3. Re: Burning a DVD with Premiere Elements 8
              First, Memorex is just about as bad a brand, as you can use. This ARTICLE will give you more background, and tips.
              As for Windows Media Center, I cannot give you a firm answer, but some years back, MS disabled the playability of DVD's, especially any burned DVD's, in an ill-fated attempt to stop piracy of © work. The assumption was made that any burned DVD must be a pirated copy. Much of that same thinking has really hampered the BD market, as Sony wanted to eliminate all producers of BD material from the market, who did not pay handsome royalties to them for the replication of BD material. Windows Media Player, for several generations, had the ability to play DVD's removed. A user had to install an add-on, to get that functionality back, or use products like CyberLink's PowerDVD, or MediaPlayer Classic HC. Not sure if that is the problem here, of if the multi-drive just can't feed a clean enough signal to Windows Media Center.
              • 4. Re: Burning a DVD with Premiere Elements 8
                blackjack94
                Similar problem (among others, such as "unknown error 2131042560"when I try to burn direct to disc)...Sucessfully saved the project to file, runs flawlessly in "Power DVD". When I try and burn it to DVD from said file, it fails to burn to disc using Cyberlink multimedia set Nero Express to burn the disc. I just made another coaster before writing this. Media is either Ritek's or Kodaks, in this last try a Ritek. See the following "Fail" Log:
                Windows XP 5.1
                IA32
                WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 08:03:20 AM
                ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 08:18:06 PM
                Nero version: 6.3.1.12 (Nero Express)
                Recorder:             <TSSTcorp DVD+-RW TS-H653B>Version: D200 - HA 1 TA 0 - 6.3.1.12
                Adapter driver:      <atapi>                   HA 1
                Drive buffer  :      2048kB
                Bus Type      :      via Inquiry data (1) -> ATAPI, detected: ATAPI
                Connected to MMC as unknown drive with class-nr : 11
                Drive is autodetected - recorder class: DVD+R9 DL recorder
                CD-ROM:               <TSSTcorp DVD+-RW TS-H653B>Version: D200 - HA 1 TA 0 - 6.3.1.12
                === Scsi-Device-Map ===
                DiskPeripheral       : ST3250820AS                      atapi Port 0 ID 0  DMA: On
                CdRomPeripheral      : TSSTcorp DVD+-RW TS-H653B        atapi Port 1 ID 0  DMA: Off
                === CDRom-Device-Map ===
                TSSTcorp DVD+-RW TS-H653   D:   CDRom0
                AutoRun : 0
                Excluded drive IDs:
                CmdQueuing     : 1
                CmdNotification: 2
                WriteBufferSize: 83886080 (0) Byte
                ShowDrvBufStat : 0
                EraseSpeed     : 0
                BUFE           : 0
                Physical memory     : 2046MB (2095208kB)
                Free physical memory: 774MB (792856kB)
                Memory in use       : 62 %
                Uncached PFiles: 0x0
                Use Static Write Speed Table: 0
                Use Inquiry    : 1
                Global Bus Type: default (0)
                Check supported media : Disabled (0)
                8.2.2011
                UDF/ISO compilation
                06:37:48 PM    #1 Phase 112 File dlgbrnst.cpp, Line 1836
                    DVD-Video files reallocation started
                06:37:48 PM    #2 Text 0 File DVDVideoCompilation.cpp, Line 543
                    Content of VIDEO_TS.IFO has been modified
                06:37:48 PM    #3 Text 0 File DVDVideoCompilation.cpp, Line 543
                    Content of VIDEO_TS.BUP has been modified
                06:37:48 PM    #4 Text 0 File DVDVideoCompilation.cpp, Line 543
                    Content of VTS_01_0.IFO has been modified
                06:37:48 PM    #5 Text 0 File DVDVideoCompilation.cpp, Line 543
                    Content of VTS_01_0.BUP has been modified
                06:37:48 PM    #6 Phase 113 File dlgbrnst.cpp, Line 1836
                    DVD-Video files reallocation completed
                06:37:48 PM    #7 Text 0 File Isodoc.cpp, Line 6065
                    Iso document burn settings
                    Determine maximum speed : FALSE
                    Simulate                : FALSE
                    Write                   : TRUE
                    Finalize CD             : TRUE
                    Multisession            : FALSE
                    Burning mode            : DAO
                    Mode                    : 1
                    ISO Level               : 1 (Max. of 11 = 8 + 3 char)
                    Character set           : ISO 9660
                    Joliet                  : TRUE
                    Allow pathdepth more than 8 directories : FALSE
                    Allow more than 255 characters in path  : FALSE
                    Write ISO9660 ;1 file extensions        : TRUE
                06:37:48 PM    #8 Phase 111 File dlgbrnst.cpp, Line 1836
                    DVD-Video files sorted
                06:37:48 PM    #9 Text 0 File Reader.cpp, Line 118
                    Reader running
                06:37:48 PM    #10 Text 0 File Writer.cpp, Line 124
                    Writer TSSTcorp DVD+-RW TS-H653B running
                06:37:48 PM    #11 ISO9660GEN -11 File geniso.cpp, Line 3899
                    First writeable address = 0 (0x00000000)
                06:37:48 PM    #12 ISO9660GEN -11 File geniso.cpp, Line 3899
                06:37:48 PM    #13 Text 0 File Burncd.cpp, Line 3167
                    Turn on Disc-at-once, using DVD media
                06:37:48 PM    #14 Text 0 File DlgWaitCD.cpp, Line 245
                    Last possible write address on media:  2297887 (510:38.37, 4488MB)
                    Last address to be written:            1255663 (279:02.13, 2452MB)
                06:37:48 PM    #15 Text 0 File DlgWaitCD.cpp, Line 257
                    Write in overburning mode: NO (enabled: CD)
                06:37:48 PM    #16 Text 0 File DlgWaitCD.cpp, Line 2137
                    Recorder: TSSTcorp DVD+-RW TS-H653B, Media type: DVD-R
                     Disc Manufacturer: RITEKG - 05
                     Disc Application Code: 64, Disc Physical Code: 193
                06:37:48 PM    #17 Text 0 File DlgWaitCD.cpp, Line 418
                    >>> Protocol of DlgWaitCD activities: <<<
                06:37:48 PM    #18 Text 0 File ThreadedTransferInterface.cpp, Line 813
                    Setup items (after recorder preparation)
                     0: TRM_DATA_MODE1 (CTransferItem)
                        2 indices, index0 (150) not provided
                        original disc pos #0 + 1255664 (1255664) = #1255664/279:2.14
                        relocatable, disc pos for caching/writing not required/required, no patch infos
                        -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1255664 blocks [TSSTcorp DVD+-RW TS-H653B]
                06:37:48 PM    #19 Text 0 File ThreadedTransferInterface.cpp, Line 982
                    Prepare recorder [TSSTcorp DVD+-RW TS-H653B] for write in CUE-sheet-DAO
                    DAO infos:
                     MCN: ""
                     TOCType: 0x00; Session Closed, disc fixated
                     Tracks 1 to 1:
                       1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    2571599872, ISRC ""
                    DAO layout:
                     __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
                           0 |  lead-in |   0 |   0x00 |  0x41
                           0 |        1 |   0 |   0x00 |  0x41
                           0 |        1 |   1 |   0x00 |  0x41
                     1255664 | lead-out |   1 |   0x00 |  0x41
                06:37:49 PM    #20 Phase 24 File dlgbrnst.cpp, Line 1836
                    Caching of files started
                06:37:49 PM    #21 Text 0 File Burncd.cpp, Line 4177
                    Cache writing successful.
                06:37:49 PM    #22 Phase 25 File dlgbrnst.cpp, Line 1836
                    Caching of files completed
                06:37:49 PM    #23 Phase 36 File dlgbrnst.cpp, Line 1836
                    Burn process started at 8x (11,080 KB/s)
                06:37:50 PM    #24 Text 0 File ThreadedTransferInterface.cpp, Line 2345
                    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
                06:37:50 PM    #25 Text 0 File dlgbrnst.cpp, Line 1694
                    Set remaining time: 4:01,635 (241635ms) -> OK
                06:37:50 PM    #26 Text 0 File DVDR.cpp, Line 1833
                    Recording mode: Sequential Recording Mode
                06:37:50 PM    #27 Text 0 File Mmc.cpp, Line 20173
                    Set BUFE: supported -> ON
                06:37:50 PM    #28 Text 0 File DVDR.cpp, Line 1974
                    Start write address at LBA 0
                    DVD high compatibility mode: Yes
                06:37:50 PM    #29 Text 0 File Cdrdrv.cpp, Line 8063
                    ---- DVD Structure: Physical Format Information (00h) ----
                    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
                     Book Type: DVD-R   (2), Part Version: 5
                     Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
                     Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
                     Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
                     Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
                     End Physical Sector Number of Data Area:      0 h
                     End Sector Number in Layer 0:                 0 h
                     Data in Burst Cutting Area (BCA) does not exist
                      Start sector number of the current Border-Out: 0 h
                      Start sector number of the next Border-In:     0 h
                     Media Specific [16..63]:
                          00 30 01 02 04 06 00 00 - 00 08 00 00 00 00 00 00    .0..............
                          00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
                06:38:06 PM    #30 Text 0 File Cdrdrv.cpp, Line 1293
                    18:38:06.437 - TSSTcorp DVD+-RW TS-H653B\H1 T0 : Queue again later
                06:43:16 PM    #31 SCSI -1135 File Cdrdrv.cpp, Line 1441
                    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x09DC0000
                    Status:     0x04 (0x01, SCSI_ERR)
                    HA-Status   0x00 (0x00, OK)
                    TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
                    Sense Key:  0x03 (KEY_MEDIUM_ERROR)
                    Sense Code: 0x0C
                    Sense Qual: 0x00
                    CDB Data:   0x2A 0x00 0x00 0x04 0xBB 0x40 0x00 0x00 0x20 0x00 0x00 0x00
                    Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
                                0x00 0x00 0x00 0x00 0x0C 0x00
                06:43:16 PM    #32 CDR -1135 File Writer.cpp, Line 304
                    Write error
                06:43:16 PM    #33 Text 0 File ThreadedTransfer.cpp, Line 229
                    all writers idle, stopping conversion
                06:43:16 PM    #34 Text 0 File ThreadedTransfer.cpp, Line 223
                    conversion idle, stopping reader
                06:43:16 PM    #35 Text 0 File DVDR.cpp, Line 2201
                    EndDAO: Last written address was 310079
                06:43:16 PM    #36 Text 0 File dlgbrnst.cpp, Line 1694
                    Set remaining time: 0:00,000 (0ms) -> OK
                06:43:16 PM    #37 Text 0 File dlgbrnst.cpp, Line 1694
                06:43:16 PM    #38 Phase 38 File dlgbrnst.cpp, Line 1836
                    Burn process failed at 8x (11,080 KB/s)
                Existing drivers:
                File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 12:07:32 PM
                File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9200 bytes, created 3/12/2008 03:00:00 AM
                File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 07:05:10 AM
                File 'Drivers\PXHELP20.SYS': Ver=3.00.93.0, size=45648 bytes, created 6/9/2010 03:01:10 PM (Prassi/Veritas driver for win 2K)
                File 'Drivers\InCDfs.SYS': Ver=4, 2, 4, 1, size=89472 bytes, created 4/6/2004 07:39:20 PM (InCD4 driver for win NT/2K/XP)
                File 'Drivers\InCDpass.SYS': Ver=4, 2, 4, 1, size=25600 bytes, created 4/6/2004 07:40:10 PM (InCD4 driver for win NT/2K/XP)
                File 'Drivers\InCDrec.SYS': Ver=4, 2, 4, 1, size=5504 bytes, created 4/6/2004 07:43:22 PM (InCD4 driver for win NT/2K/XP)
                File 'Drivers\atapi.sys': Ver=5.1.2600.5512 (xpsp.080413-2108), size=96512 bytes, created 4/13/2008 10:40:30 AM (Adapter driver for rec)
                Registry Keys:
                HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 1 (Security Option)
                I love this program when it works when I need it to, but It seldom does work, and since I paid full price for it, I'm not gonna kiss *** and shower Adobe products with Kudos. If your stuff fails in the crunch when you need it most, it sux'!.  So far this program has not lived up to expectations.  I'm going to try and see if I can get a sucessful burn with another program now, 1855hrs, tuesday...
                • 5. Re: Burning a DVD with Premiere Elements 8
                  Things and Software to AVOID when authoring/burning a DVD
                  Read all links/sub-links to create a "best" burned disc
                  Start --> http://forums.adobe.com/thread/608660?tstart=0
                  #2 here has WHY Explained http://forums.adobe.com/thread/607390
                  Plus http://forums.adobe.com/thread/562941?tstart=0
                  Write to a folder and use the free http://www.imgburn.com/index.php?act=download to write to disc
                  If that works... you have the problem described above
                  • 6. Re: Burning a DVD with Premiere Elements 8
                    nealeh Level 5
                    Many, including myself, use the free ImgBurn to burn DVD's. It's quick and easy, has hilarious status messages (hard core British humour), and lets you adjust burn speed (I use x4). It also provides good information on who really made the DVD blanks you are using.
                    Cheers,
                    Neale
                    • 7. Re: Burning a DVD with Premiere Elements 8
                      nealeh Level 5
                      A quick Google for error 2131042560 shows this happens with many video editing software. The only other report for that error in these forums was never successfully resolved so you may have more luck following some of the links in those Google results for a solution.
                      Cheers,
                      Neale
