4 Replies Latest reply on Feb 9, 2011 2:01 PM by Olav Martin Kvern
    How to access elements in main.mxml from ActionScript file?
    MChan4WTBTS
      I am having difficulties creating a panel using the Extension Builder SDK. It seems that all the examples explain how to control a CS5 document using a panel, but I have not found any examples of how to control the elements of the panel via the ActionScript.   By the way we are using CS Extension Builder SDK with Flash Builder 4.  Here is a simple example of were I am getting stuck.
      I create a Extension builder project for a PS panel named: "CSExtensionTest".  In the main.mxml file a create a button with id="btnPSCode".
      File:
      main.mxml
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" historyManagementEnabled="false">
      <mx:Script>
                   <![CDATA[
      Bindable]
                          private var hostName:String = HostObject.mainExtension;
            </mx:Script>
      <mx:VBox height="100%" width="100%" verticalAlign="middle" horizontalAlign="center">
      <mx:Button id="btnPSCode" label="Run PS code" click="CSExtensionTestPhotoshop.run()" enabled="{hostName.indexOf('photoshop') > -1}"/>
      <mx:Button id="btnJSXCode" label="Run JSX code" click="CSExtensionTestJSX.run()"/>
      </mx:VBox>
      </mx:Application>
      How can i get access to the properties of this element in the CSExtensionTesJSX.as file?
      File:
      package
      import com.adobe.csxs.core.CSXSInterface;
      import com.adobe.csxs.core.csxs_internal;
      import com.adobe.csxs.types.SyncRequestResult;
      import mx.binding.utils.BindingUtils;
      import mx.core.ButtonAsset;
      import mx.core.mx_internal;
      import mx.utils.object_proxy;
      public class CSExtensionTestJSX
      public static function run():void
      var myCSXS:CSXSInterface = CSXSInterface.getInstance();
      var result:SyncRequestResult = CSXSInterface.instance.evalScript("jsxFunction");
                          btnPSCode.enabled = false;
      I'm getting this error:
      I had originally written a panel using a Flex Project and was able to access the properties of the elements of the main.mxml file directly.  It seems I can't do that anymore.  Am I missing something in the code?  Am I missing some type of library?  I'm sorry I am not very experienced in Adobe development, but we are trying to get more involved in developing plugins and extensions for CS5.  Any help will be greatly appreciated.
        • 1. Re: How to access elements in main.mxml from ActionScript file.
          david_a_clark Adobe Employee
          You need to pass a reference to your main mxml object into the run method. For example:
          main.mxml:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" historyManagementEnabled="false">
              <mx:Script>
                  <![CDATA[
                      [Bindable]
              </mx:Script>
                  <mx:Button id="myButton" label="Run JSX code" click="testJSX.run(this)"/>
              </mx:VBox>
          </mx:Application>
          testJSX.as:
          package
              import mx.controls.Button;
              public class testJSX
                  public static function run(m:main):void
                      var b:Button = m.myButton;
          HTH.
          • 2. Re: How to access elements in main.mxml from ActionScript file.
            MChan4WTBTS Level 1
            Thank you David for your quick response.  I really appreciate it.  It totally makes sense, but I'm still getting an error with the example you provided.
            I am getting this error on the statement:   var b:Button = m.myButton;
            Resource Description Path Location Type
            CSExtensionTestJSX.as 1120: Access of undefined property m. /CSExtensionTest/src line 24 Flex Problem
            Sorry for my inexperience in this platform.  Hoping to get better at it.  Again Thank you.
            • 3. Re: How to access elements in main.mxml from ActionScript file.
              MChan4WTBTS Level 1
              Opps... My fault.  Just figured out waht was missing.
              I forgot to enter the following on the funciton line.
              Again Thank you.
              • 4. Re: How to access elements in main.mxml from ActionScript file.
                Olav Martin Kvern Level 3
                Hi MChan4WTBTS,
                When you're responding to a click event, as in David's example, you can also just pass the event. The event.target will be a reference to the button itself.
                You can find some examples of this on the CS SDK blog, at:
                http://blogs.adobe.com/cssdk/
                Ole
