1 Reply Latest reply on Aug 13, 2006 2:36 PM by Newsgroup_User
    What's the difference
    timothytrice
      Besides the fact that one works and the other does not (the for loop does not display the images), what in the world is the difference between these two scripts?
      Works:
      [CODE]
      this.createEmptyMovieClip("logo_mc", this.getNextHighestDepth());
      logo_mc.loadMovie("1.jpg");
      logo_mc._x = 20;
      logo_mc._y = 20;
      this.createEmptyMovieClip("logo_mc1", this.getNextHighestDepth());
      logo_mc1.loadMovie("2.jpg");
      logo_mc1._x = 200;
      logo_mc1._y = 20;
      this.createEmptyMovieClip("logo_mc2", this.getNextHighestDepth());
      logo_mc2.loadMovie("3.jpg");
      logo_mc2._x = 380;
      logo_mc2._y = 20;
      [/CODE]
      Does not work:
      [CODE]
      for (i=1;i<=3;i++) {
      switch (i) {
      case 1:
      logo_mc._x = 20;
      logo_mc._y = 20;
      break;
      case 2:
      logo_mc1._x = 200;
      logo_mc1._y = 20;
      break;
      case 3:
      logo_mc2._x = 380;
      logo_mc2._y = 20;
      break;
      [/CODE]
      Would really appreciate any suggestions as it's really killing my program.
      Tim
        • 1. Re: What's the difference
          Level 7
          Tim,
          > Does not work:
          > [CODE]
          > switch (i) {
          > case 1:
          createEmptyMovieCip() is a method, not a function. Conceptually,
          they're the same thing, but methods belong to a class, while functions are
          "free floating" and "just are." In your original code, you're using the
          global "this" property to reference an object -- presumably, the main
          timeline, which is a movie clip. Because it's a movie clip, it is an
          instance of the MovieClip class, which means it has all the functionality
          defined by the MovieClip class, including the
          MovieClip.createEmptyMovieClip() method.
          Without the "this" or some other movie clip reference, it may be that
          your method simply isn't firing. I notice you *are* using "this" in the
          MovieClip.getNextHighestDepth() method later in that same line.
          I made a test real quick -- nothing more than the following in a blank
          FLA:
          createEmptyMovieClip("a", 0);
          ... and that did, indeed, create a new MovieClip instance, named "a" (as
          verified in the Debugger panel). Do to this result, I'm not convinced your
          lack of "this" is the cause, but it certainly is a difference between your
          two attemps.
          Another thing ...
          > logo_mc._x = 20;
          > logo_mc._y = 20;
          You may have problems with that next part because of the fact that
          you're loading external content. While 1.jpg may load instantly on your own
          machine, it may not when requested from a server. The problem with these
          lines is that *while* 1.jpg is being loaded, the remaining ActionScript is
          executed, without waiting until the JPG loaded completely. Depending on
          what you're trying to do, this could lead you toward unexpected or erroneous
          results.
          The solution is to wait until your external content has loaded
          completely.
          http://www.quip.net/blog/2006/flash/how-to-tell-when-external-swf-loaded
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
