5 Replies Latest reply on Feb 9, 2011 12:25 PM by kglad
    Rotate in 3D
    Yurosis09
      I'm a beginner to Flash and would like to ask for directions to get started with what I'm trying to achieve.
      I've got a 3D model at hand, which I have imported as a movie and an image sequence of each frame depending on which is necessary. I basically would want to rotate it by 360 degree both on the x and y axis on a canvas as well as having that done manually, such as having to drag my mouse to control which direction the model rotates in. Can I do this in Flash?
      Help is very much appreciated.
      Thanks!
        • 1. Re: Rotate in 3D
          flash can rotate 2d objects in 3d space.  if you have a 3d object that you want to rotate in 3d space flash can do that but you'll probably want to use a mature framework like papervision 3d.
          • 2. Re: Rotate in 3D
            Yurosis09 Level 1
            Hello,
            I've downloaded Papervision 3D but am having some trouble with integrating it into Flash Pro CS5 as described by the installation guide that came with the download. That aside I have not a clue how to start with Papervision 3D or Flash after importing the movie or frames.
            • 3. Re: Rotate in 3D
              if you're comfortable with actionscript you should be able to use the sample files to get your project going.  if you're a novice actionscripter this will be a major challenge.
              • 4. Re: Rotate in 3D
                Yurosis09 Level 1
                I'd have to say I'm a novice at scripting.
                Are there any other approaches I can take then? All I really need is the rotation to be manually controlled and for it to rotate 360 degrees on the x and y axis.
                • 5. Re: Rotate in 3D
                  if you have a sequence of flat images that can be distributed along a movieclip timeline, you can animate your object by controlling the timeline.
