5 Replies Latest reply on Jun 25, 2007 11:09 AM by Newsgroup_User
    Help with Slices
    Chris Goodiel
      Hello all,
      I am running into a problem at the moment trying to transition over to FW CS3. I used Image Ready before and I am used to the way I set things up for images/slices and trying to find the similar way to set it up in FW.
      I already have code set up for a rollover in DW so I have no use to export a rollover from the FW. How I used to set up my space in ImageReady was I would create duplicate slices one with the name _on and the other with the name _off each in there own slice set, these would correspend with on and off layers of a button state.
      I have tried in FW cs3 to create duplicate slices each in there own web sublayer naming one off with each off state name_off slices and the other on with name_on slices. I turned the on layers on and the on slices on and exported the slices just fine. The problem happened when I turn the on stuff off and the off layers and slices on and try to export I get nothing.
      I moved the off slices to the right of the on slices and tried to export and it exported images but if I move them back over the same location they will export nothing.
      If you understand my problem and have a solution other than moving the on off images away from each other please respond.
      Thanks for your help in advance,
      Chris
        • 1. Re: Help with Slices
          Level 7
          Chris Goodiel wrote:
          > Hello all,
          > button state.
          > export nothing.
          > Chris
          Chris can you post a link to the file? It will help us work through
          things better.
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          Extending Knowledge, Daily
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          news://forums.macromedia.com/macromedia.fireworks
          news://forums.macromedia.com/macromedia.dreamweaver
          • 3. Re: Help with Slices
            Level 7
            Hi Chris,
            Instead of creating the images on separate web layers, create them in
            separate frames. You can duplicate frame 1 and just change the look of
            the buttons in frame two. When you export, use the Frames to Files
            option, FW will automatically give the images on the frame 2 a label
            designating which frame they are from.
            Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
            http://www.projectseven.com
            Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
            CSS Newsgroup: news://forums.projectseven.com/css/
            http://www.adobe.com/communities/experts/
            • 4. Re: Help with Slices
              Level 7
              Linda Rathgeber **Adobe Community Expert - Fireworks** wrote:
              > Hi Chris,
              Linda beat me to it
              • 5. Re: Help with Slices
                Level 7
                > http://www.chrisgoodieldesigns.com/AFT_NewHomePage_FLAT.png
                Here's your PNG file reworked to demonstrate what I mean by putting the
                rollover images on 2 frames. Right click to download, and then open it
                in FW.
                http://www.playingwithfire.com/PageNew.png
