2 Replies Latest reply on Feb 10, 2011 9:24 AM by Ococ
    Drawing artifacts with motion under a gradient mask
    Ococ
      Hello,
      I am having an issue with using a motion under a gradient mask and was hoping someone might have a solution. I have a  transparent png bubble in movie clips that are being randomly sized and  animation started using code. The design has a reflection and I am  using a gradient mask for the effect. The issue is when the bubbles  animate they are causing drawing artifacts. Please see the attached  screen shot or you can see the swf here - http://archetypeworks.com/test/tm/. Below is the code I am using to set the mask. Any help or  suggestions are appreciated.
      Code:
      bottomMask.cacheAsBitmap = true;
      beaker_bottom.cacheAsBitmap = true;
      beaker_bottom.mask = bottomMask;
      Thank you,
      Ococ
