30 Replies Latest reply on Mar 18, 2014 2:01 PM by Ged_mc
    StageVideo usage from Flex Application?
    yamalight
      Hello everyone!
      I'm trying out new StageVideo class and if I add it pure AS3 project everything works perfect.
      But if I try to use the same code in Flex project I get no video output, but looks like the video itself is playing ('cos I can hear the sound track).
      I've tried to remove everything from mxml file to make sure nothing covers video, tried to remove all background changes and etc. (put here any other stuff that might overlay stage), but nothing helped.
      Is it possible to use StageVideo from Flex app at all? May be there's some trick to it?
      Can someone help? Thanks in advance!
        • 1. Re: StageVideo usage from Flex Application?
          Flex harUI Adobe Employee
          Try an application skin with just a contentGroup as in:
          <s:Skin
              xmlns:fx="http://ns.adobe.com/mxml/2009"
              <fx:Metadata>
                  [HostComponent("spark.components.Application")]
              </fx:Metadata>
              <s:states>
                  <s:State name="normal" />
                  <s:State name="disabled" />
              </s:states>
              <s:Group id="contentGroup" width="100%" height="100%" x="0"
          y="0"></s:Group>
          </s:Skin
          • 2. Re: StageVideo usage from Flex Application?
            yamalight Level 1
            Ah, super! Now everything works perfect Thanks a lot!
            • 3. Re: StageVideo usage from Flex Application?
              archemedia Level 4
              Maybe not directly connecte to this thread but since you're using stageVideo, you might also know if it's possible to access video's made with an iPad from within your Flex application?
              Thx,
              Dany
              • 4. Re: StageVideo usage from Flex Application?
                yamalight Level 1
                archemedia, yep, it's possible. with some limitations though
                • 5. Re: StageVideo usage from Flex Application?
                  archemedia Level 4
                  thx yamalight for your reaction. I've been browsing and browsing for some topics on this but wasn't able to find something usefull. I can access the CameraRoll on iPad but unlike other applications, it contains no video's. I can't find anything in the API for this. The same goes for iTunes music access. Any ideas?
                  thx,
                  Dany
                  • 6. Re: StageVideo usage from Flex Application?
                    yamalight Level 1
                    haven't worked with iOS yet, only android so far, sorry :| but search gives quite a lot of results here on forums about video on iOS
                    • 7. Re: StageVideo usage from Flex Application?
                      Ged_mc
                      Hi Yamalight,
                      Please can you share some code for the solution - we're having the same issue but I'm not sure how giving the Application a skin helps.
                      Ged
                      • 8. Re: StageVideo usage from Flex Application?
                        yamalight Level 1
                        Ged_mc wrote:
                        Hi Yamalight,
                        Ged
                        Take a look at Flex harUI message - that's the recipe. Just create new flex skin, make content-only and problem solved
                        • 9. Re: StageVideo usage from Flex Application?
                          leejk Level 1
                          Will this work with a mobile application though using the ViewNavigatorApplication tag? It doesn't seem to here.
                          • 10. Re: StageVideo usage from Flex Application?
                            Ged_mc Level 1
                            Hi Keith,
                            We got stage video working on ios using  Vimeo pro to deliver the video.
                            You haveto think of it as playing underneath your project. So hide all display list above it and build UI around it.
                            We didn't use ViewNavigatorApplication   so I don't know.
                            However ViewNavigatorApplication will just be a visual layer over the stage video.
                            Find a way to hide it then rebuild your UI around the stage video to make it appear to be in your app..
                            • 11. Re: StageVideo usage from Flex Application?
                              leejk Level 1
                              Hello,
                              I have a very simple test mobile project I am trying to get video working in. If I post it here would you be willing to take a look at it? For the life of me I can't figure out the problem.
                              thx
                              • 12. Re: StageVideo usage from Flex Application?
                                yamalight Level 1
                                Sure, go for it. If I can help, I will
                                • 13. Re: StageVideo usage from Flex Application?
                                  leejk Level 1
                                  Hello,
                                  I guess there is no way to attach files to this post. I made the main app an Application instead of a ViewNavigatorApplication for simplicity sake. It's a basic mobile application project for an ipad, so in Flash Builder just create a basic project using that profile and drop these in. I appreciate you taking a look at it.
                                  thx
                                  Main.mxml
        creationComplete="init()">
                                  <fx:Declarations>
                                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                                  </fx:Declarations>
                                  <fx:Script>
                                                      <![CDATA[
        private var mediaPlayer:CatVideoPlayer;
        private function init():void
        var videoFile:File = File.applicationDirectory.resolvePath("preview.mp4");
        var videoPath:String = new File(new File(videoFile.url).nativePath).url;
        mediaPlayer = new CatVideoPlayer();
        mediaPlayer.width = 640;
        mediaPlayer.height = 360;
        addElement(mediaPlayer);
        mediaPlayer.source = videoPath;
                                  </fx:Script>
                                  </s:Application>
                                  Custom UI Component:
                                  package
                                            import flash.display.Bitmap;
                                            import flash.display.BitmapData;
                                            import flash.display.Sprite;
                                            import flash.display.StageAlign;
                                            import flash.display.StageScaleMode;
                                            import flash.events.Event;
                                            import flash.events.StageVideoAvailabilityEvent;
                                            import flash.events.StageVideoEvent;
                                            import flash.geom.Rectangle;
                                            import flash.media.StageVideo;
                                            import flash.media.StageVideoAvailability;
                                            import flash.media.Video;
                                            import flash.net.NetConnection;
                                            import flash.net.NetStream;
                                            import mx.core.FlexGlobals;
                                            import mx.core.UIComponent;
                                            public class CatVideoPlayer extends UIComponent
                                                      private var _defaultHeight:Number = 360;
                                                      private var _defaultWidth:Number = 640;
                                                      private var _ns:NetStream;
                                                      private var _obj:Object;
                                                      private var _source:String;
                                                      private var _sourceChanged:Boolean;
                                                      private var _stageBitmap:Bitmap;
                                                      private var _stageVideoAv:Boolean = false;
                                                      private var _sv:StageVideo;
                                                      private var _vd:Video;
                                                      private var _vidMask:Sprite;
                                    //private var _videoStage:Sprite;
                                                      public function CatVideoPlayer()
        super();
        mouseEnabled = false;
        addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                                                      public function onCuePoint(info:Object):void
                                    trace("CatVideoPlayer.onCuePoint: time=" + info.time + " name=" + info.name + " type=" + info.type);
                                                      public function onMetaData(info:Object):void
                                    //trace("metadata: duration=" + info.duration + " width=" + info.width + " height=" + info.height + " framerate=" + info.framerate);
                                    //this.width = info.width;
                                    //this.height = info.height;
                                                      public function onPlayStatus(info:Object):void
                                    trace("CatVideoPlayer.onPlayStatus: " + info.data);
                                                      public function onXMPData(info:Object):void
                                    trace("CatVideoPlayer.onXMPData: " + info.data);
                                                      public function set source(value:String):void
        _source = value;
        _sourceChanged = true;
        invalidateProperties();
                                                      override protected function commitProperties():void
        super.commitProperties();
        if (_sourceChanged)
        setState("showVideoPlayer");
        _sourceChanged = false;
                                                      override protected function createChildren():void
        super.createChildren();
                                    trace("createChildren fired in CatVideoPlayer");
                                    //_videoStage = new Sprite();
                                    //addChild(_videoStage);
                                                      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
        super.updateDisplayList(unscaledWidth, unscaledHeight);
                                                       * Convert the current screen to a bitmap and mask it to show stageVideo.
                                                      private function convertStageToBitmap():void
        var bitmapData:BitmapData = new BitmapData(FlexGlobals.topLevelApplication.width, FlexGlobals.topLevelApplication.height);
        _stageBitmap = new Bitmap();
        _vidMask = new Sprite();
        _vidMask.graphics.beginFill(0x000000);
        _vidMask.graphics.moveTo(0, 0);
        _vidMask.graphics.drawRect(0, 0, _defaultWidth, _defaultHeight);
        _vidMask.graphics.endFill();
                                    //bitmapData.draw(this);
        bitmapData.draw(FlexGlobals.topLevelApplication.document);
        _stageBitmap.bitmapData = bitmapData;
        _stageBitmap.cacheAsBitmap = true;
        _vidMask.cacheAsBitmap = true;
                                    //addChild(_vidMask);
        _stageBitmap.mask = _vidMask;
                                    //addChild(_stageBitmap);
                                    //backgroundImg_mc.visible = false;
                                    //playerWindow_mc.visible = false;
                                    //initVideo();
                                                       * Handles the mouse clicks that occur on UI components.
                                                       * @param e
                                                      private function handleInterfaceClick(e:Event):void
        e.preventDefault();
        switch (e.target.name)
                                    case "playBtn_mc":
        break;
                                    case "closeVideo_mc":
        setState("closePlayer");
        break;
                                    default:
                                    //do default
                                                       * Plays the video using StageVideo if supported.
                                                      private function initVideo():void
        var nc:NetConnection = new NetConnection();
        nc.connect(null);
        _ns = new NetStream(nc);
        _obj = new Object();
        _ns.client = _obj;
        _ns.bufferTime = 2;
        _ns.client = _obj;
                                    //_obj.onMetaData = MetaData;
                                    //_obj.onCuePoint = CuePoint;
        if (_stageVideoAv)
                                    //use stageVideo
                                    trace("using stage video in CatVideoPlayer.initVideo()");
        _sv = stage.stageVideos[0];
        _sv.addEventListener(StageVideoEvent.RENDER_STATE, onRender);
        _sv.attachNetStream(_ns);
                                    else
                                    //fallback to video class
                                    trace("using normal video in CatVideoPlayer.initVideo()");
        _vd = new Video(_defaultWidth, _defaultHeight);
                                    //_vd.x = 152;
                                    //_vd.y = 143;
        addChild(_vd);
        _vd.attachNetStream(_ns);
                                    //addChild(videoUI_mc);
        _ns.play(_source);
                                                      private function onAddedToStage(event:Event):void
                                    trace("onAddedToStage fired in CatVideoPlayer");
        stage.scaleMode = StageScaleMode.NO_SCALE;
        stage.align = StageAlign.TOP_LEFT;
        stage.addEventListener(StageVideoAvailabilityEvent.STAGE_VIDEO_AVAILABILITY, onStageVideoAvailability);
                                                      private function onRender(e:StageVideoEvent):void
                                  //                              if (!videoUI_mc.fsMode)
                                  //                                        _sv.viewPort = new Rectangle(152, 143, 720, 480);
                                  //                              else
        _sv.viewPort = new Rectangle(0, 0, 640, 360);
                                                      private function onStageVideoAvailability(e:StageVideoAvailabilityEvent):void
        _stageVideoAv = (e.availability == StageVideoAvailability.AVAILABLE);
        initVideo();
                                                       * Animate the video player's UI states.
                                                       * @param currentState The different states the player is in.
                                                      private function setState(currentState:String):void
                                    trace("setState fired in CatVideoPlayer");
        switch (currentState)
                                    case "showVideoPlayer":
                                    //playBtn_mc.visible = false;
                                    //addChild(playerWindow_mc);
                                    //addChild(closeVideo_mc);
                                    //playerWindow_mc.visible = true;
                                    //closeVideo_mc.visible = true;
                                    //TweenLite.from(playerWindow_mc, 1, { alpha:0, onComplete:function(){ convertStageToBitmap(); } });
                                    //TweenLite.from(closeVideo_mc, 1, { alpha:0 });
        break;
                                    case "closePlayer":
                                    //removeVideoPlayer();
                                    //playBtn_mc.visible = true;
        break;
                                    default:
                                    //do default
                                  • 14. Re: StageVideo usage from Flex Application?
                                    yamalight Level 1
                                    It seems that the solution to this post should help. Just create a new skin that doesn't have background.
                                    • 15. Re: StageVideo usage from Flex Application?
                                      leejk Level 1
                                      Is there a link?
                                      Also, I've tried setting the background alpha to 0 for the main application... I think there must be another layer there somewhere though that is blocking the video.
                                      • 16. Re: StageVideo usage from Flex Application?
                                        yamalight Level 1
                                        You have to create a custom skin. Setting BG alpha to 0 doesn't work (or at least it didn't worked for me).
                                        See example at top of this thread: http://forums.adobe.com/message/3459444#3459444
                                        You just need a new skin with only content group and no BG at all. Then it works fine.
                                        Also, you can take a look at my custom player here, it works on desktop, web and mobile with StageVideo support: https://github.com/yamalight/libcodezen/tree/master/src/com/codezen/component/videoplayer
                                        • 17. Re: StageVideo usage from Flex Application?
                                          leejk Level 1
                                          I still can't seem to get it right. Here is my app skin:
                                          <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                              xmlns:s="library://ns.adobe.com/flex/spark">
                                          <!-- host component -->
                                          <fx:Metadata>
                                                              [HostComponent("spark.components.ViewNavigatorApplication")]
                                          </fx:Metadata>
                                          <!-- states -->
                                          <s:states>
                                            <s:State name="landscapeAndOverlay" />
                                            <s:State name="portraitAndOverlay" />
                                                              <s:State name="landscape" />
                                                              <s:State name="portrait" />
                                          </s:states>
                                          <!-- SkinParts
                                                    name=contentGroup, type=spark.components.Group, required=false
                                                    name=actionBar, type=spark.components.ActionBar, required=false
                                                    <s:Group id="contentGroup" width="100%" height="100%" x="0" y="0"/>
                                                    <s:ViewNavigator id="navigator" width="100%" height="100%"/>
                                          </s:Skin>
                                          And here is the main app mxml:
                                          <s:ViewNavigatorApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
        firstView="views.MainHomeView"
        skinClass="appSkin">
                                          <fx:Declarations>
                                          </fx:Declarations>
                                          </s:ViewNavigatorApplication>
                                          The video is playing obviously because I can hear it.
                                          • 18. Re: StageVideo usage from Flex Application?
                                            Setting up an Android fil
                                            @Keith Lee
                                            i have used CatVideoPlayer stage video with web Flex project it work fine but without a skin (button and stop button),
                                            but when i try work with a Flex mobile project it's not worky unfortunaltely even i don't hear the video even like Keith Lee.
                                            i wondered if that is related with ViewNavigatorApplication hasn't background alpha attribute???
                                            • 19. Re: StageVideo usage from Flex Application?
                                              Ged_mc Level 1
                                              Our stageVideo experience was as follows:
                                              We used video display in the Web app and Android mobile project
                                              On android devices we found it unreliable across different android versions / devices. For the web we judged it too flaky given the hardware depedence.
                                              StageVideo worked well  on iOS ( iPad2 and 3 )
                                              Our iPad project didn't use the ViewNavigatorApplication
                                              We constructed it using traditional flex groups and states.
                                              The stage video source is HTTP Live streaming ( via Vimeo pro - Excellent service ) - which is App Store OK.
                                              When the stage video plays we set the app backgroundAlpha to zero and reconstructed the UI around the video ( never on top of  it ).
                                              The android situation was disappointing. I think Adobe has to get this to work reliably.
                                              • 20. Re: StageVideo usage from Flex Application?
                                                leejk Level 1
                                                I am beginning to think that the skin used in a mobile project is somehow blocking the video. Many have said they have gotten StageVideo to work on an iPad, but I don't think I have run across anyone yet who has done it in a Flex mobile project. It should work in theory though
                                                • 21. Re: StageVideo usage from Flex Application?
                                                  leejk Level 1
                                                  Well, I finally got all of this working. The culprit all along was the application skin; I had to assign a mask to it in order for the stage video to show through.
                                                  Now though i have another problem. Because the TabbedNavigatorApplication has a skin that defines a graphic for the application background, I have to assign the video mask to the skin, so anything in the display list is now a child of that mask. This is a problem because on my video player, I want to capture mouse down or touch events so that I can show/hide the video controls. Since it is masked, no matter what I try I can't seem to capture any of those events within the unmasked area which allows the stage video to show thru. Anyone know of any suggestions?
                                                  • 22. Re: StageVideo usage from Flex Application?
                                                    I don’t think you should be using a mask.  I think you should be drawing background with alpha=0.
                                                    • 23. Re: StageVideo usage from Flex Application?
                                                      leejk Level 1
                                                      Yes, that too, but because the application skin is using an embedded image for the application background, I had to mask it in order for stage video to appear. Anyway I was trying to add the event listener to the mask, which did not work, so I added it to the stage object, and that so far has allowed me to capture mouse clicks positions and determine if the video is being clicked on or not.
                                                      Now the final problem is that I cannot display the video's ui controls over the top of the video, because the mask in the application skin is masking every child object of the application. I am now considering as a solution to simply cut a hole in the application background image instead of using a mask, but I wondering if it is possible to swap application backgrounds on the fly without seeing a display hiccup?
                                                      • 24. Re: StageVideo usage from Flex Application?
                                                        Theoretically, the contentGroup, which parents all the child controls in the skin should have no background at all, and some other control outside (and behind) the contentGroup is showing the backgroundImage.  Then you can cut holes in the backgroundImage by applying your mask only to the backgroundImage and it should not be affecting anything else.
                                                        • 25. Re: StageVideo usage from Flex Application?
                                                          leejk Level 1
                                                          Hmm... I am using an Actionscript only skin, not an mxml skin. So correct me if I'm wrong, but you are saying that if I were using an mxml skin that I could make the background alpha of the contentGroup 0, add the background image to the skin outside of the contentGroup container, and then only apply the mask to the image? If so I will try that.
                                                          thx
                                                          • 26. Re: StageVideo usage from Flex Application?
                                                            Yes, and you should be able to do the same in ActionScript as well.
                                                            • 27. Re: StageVideo usage from Flex Application?
                                                              Let me clarify a bit further.  You shouldn’t need to set alpha on the contentGroup to 0, but if there is space around the backgroundImage, you could draw a rectangle with alpha=0 in that area.
                                                              • 28. Re: StageVideo usage from Flex Application?
        leejk Level 1
        I was able to solve the problem by applying the mask to the background image in the ActionScript skin, vs. applying it to the skin. That prevented the mask from affecting all child objects of the application. MXML skins are confusing . Flex is really is cool once you grasp it; i can't see why the industry is moving away from it.
        thx
        • 29. Re: StageVideo usage from Flex Application?
        David_Welch Level 1
        Maybe you should post the specific code on how you got this to work, it might help others...including me ;-)
        • 30. Re: StageVideo usage from Flex Application?
        Ged_mc Level 1
        Note we're using Stage video for IOS ipad only with no fallback - since
        it's reliable
        /// IOS
        VIDEO///////////////////////////////////////////////////////////////////////////////////// //////
        //public var videoDefinitionSource:String = 'SD';  // can be HD, SD, LD
        private var stageVideoSetup:Boolean = false
        private var nc:NetConnection;
        private var ns:NetStream;
        private var sv:StageVideo;
        private var videoToPlayVid:VideoVO;
        public function playVideo(vid:VideoVO, goMenuAfter:Boolean):void{
        kvidFrame.setDummyVideoVisibility(true);
        //loadingInProgress = true;
        loadingInProgressSwitch(true)
        if(!stageVideoSetup){
        videoToPlayVid = vid;
        setUpStageVideo();
        else{
        if(ns){
        ns.play(getSourceDef(vid))
        this.setStyle('backgroundAlpha', '0.0')   // IMPORTANT TURNS THE STAGE
        TRANSPARENT SO STAGE VIDEO CAN BE SEEN
        //showLowerBandButton = false;
        if(goMenuAfter){
        appVideoGoBackToState = "userHomeState"
        }else{
        appVideoGoBackToState = this.currentState;
        this.currentState = 'videoPlayer'
        private function handleVideoResult(event:ResultEvent):void{
        inAppVideoArray = [];
        inAppVideoArray =  event.result as Array;
        /* private function loadLowerbandVideo():void{
        videoDefinitionSource = goLowerVideoBandBut.label
        if(isIpad3){
        if(videoDefinitionSource =='SD'){
        goLowerVideoBandBut.label = 'LD'
        }else if(videoDefinitionSource =='HD'){
        goLowerVideoBandBut.label = 'SD'
        }else{
        goLowerVideoBandBut.label = 'HD'
        }else{
        }else{
        if(ns){
        ns.close();
        ns.play(getSourceDef(videoToPlayVid))
        playPauseButton.selected = true;
        public function goUserMenuAndPlayVideo(_videoCode:String,
        goMenu:Boolean):void{
        var selectedVideo:VideoVO = null;
        // get the video VO
        for each ( var v:VideoVO in inAppVideoArray){
        if (v.videoCode == _videoCode){
        selectedVideo = v;
        break;
        if(selectedVideo){
        //KVideoGroup.loadKVideo( selectedVideo, newScaleXY)
        playVideo(selectedVideo, goMenu)
        // PLAY VIDEO
        //this.currentState = 'videoPlayer'
        // register as watched with user
        videoService.firstImpressionVideoWatched()
        // hack update the userVo
        activeUser.firstImpressionVideos = ' ' _videoCode;
        public function videoStatusChange(_status:String):void{
        // called from KomodoVideoGroup
        if(_status == 'complete' ){
        playPauseButton.selected = false;
        if(_status == 'playing' ){
        protected function playPauseButton_clickHandler(event:MouseEvent):void
        //KVideoGroup.kVidPlayer_clickHandler()
        if(ns){
        ns.togglePause()
        //Toggle play pause
        public function showVideoLowerBandButton(lblText:String):void{
        //goLowerVideoBandBut.label = lblText;
        //showLowerBandButton = true;
        protected function setUpStageVideo():void
        nc = new NetConnection();
        nc.connect(null);
        ns.client = this;
        ns.addEventListener(NetStatusEvent.NET_STATUS, onNetStreamStatus);
        onStageVideoAvailable);
        private function onNetStreamStatus(event:NetStatusEvent):void
        var info:Object = event.info;
        switch (info.code)
        case "NetStream.Play.Start":
        //ns.seek(0);
        kvidFrame.setDummyVideoVisibility(false);
        //loadingInProgress = false;
        loadingInProgressSwitch(false)
        break;
        case "NetStream.Play.Stop":
        //ns.seek(0);
        if(!loadingInProgress){
        // video is complete go back
        goVideoBack()
        break;
        case "NetStream.Buffer.Full":
        //kvidFrame.setDummyVideoVisibility(false);
        break;
        public function onMetaData(obj:Object):void
        public function onPlayStatus(obj:Object):void
        if(obj.code == 'NetStream.Play.Complete'){
        public function onXMPData(obj:Object):void
        private function getSourceDef(v:VideoVO):String{
        /* var src:String = v.sourceSD
        if(videoDefinitionSource=='LD'){
        src = v.sourceMOB
        }else if(videoDefinitionSource == 'HD'){
        src = v.sourceHD
        var src:String = v.sourceHLS;
        return src;
        protected function
        onStageVideoAvailable(event:StageVideoAvailabilityEvent):void
        var point:Point = new Point((mainGroup.x + kvidFrame.x +
        kvidFrame.dummyVideo.x), (mainGroup.y + kvidFrame.y +
        kvidFrame.dummyVideo.y));
        if (event.availability == "available")
        stage.removeEventListener(StageVideoAvailabilityEvent.STAGE_VIDEO_AVAILABILITY,
        sv.attachNetStream(ns);
        sv.addEventListener(StageVideoEvent.RENDER_STATE, onRenderState);
        sv.viewPort = new Rectangle(point.x, point.y, kvidFrame.videoWidth,
        kvidFrame.videoHeight);
        stageVideoSetup = true;
        if(ns){
        ns.play(getSourceDef(videoToPlayVid));
        else{
        // NO FALLBACK
        protected function onRenderState(event:StageVideoEvent):void
        trace("StageVideo Render Status (software/hardware): " + event.status);
        /* protected function button1_clickHandler(event:MouseEvent):void
        // TODO Auto-generated method stub
        //ns.close();
        ns.close();
        //onStartVideoClicked();
        protected function pause_clickHandler(event:MouseEvent):void
        ns.togglePause()
        /// END IOS
