4 Replies Latest reply on Feb 13, 2011 11:06 AM by Shongrunden
    Simple Layout Question
    mr_payne
      Hi Gang,
      [Bindable]
      var theLayout:string = "Horizontal";
      <fx:Declarations>
           <s:BasicLayout id="Single"/>
           <s:HorizontalLayout id="Horizontal" gap="5" variableColumnWidth="true"/>
           <s:VerticalLayout id="Verticle" gap="5" variableRowHeight="true"/>
           <s:TileLayout id="Tiled"/>
      </fx:Declarations>
      how to I pass "theLayout" value into my DataGroup
      <s:DataGroup  id="ProductsDataGroup" layout = {theLayout} ...??
      </s:DataGroup>
        • 1. Re: Simple Layout Question
          Flex harUI Adobe Employee
          You can't pass a string.
          var theLayout:LayoutBase = new HorizontalLayout;
          • 2. Re: Simple Layout Question
            Andrei Kouzmenkov Level 1
            In Spark what you need to pass is an instance of one of Layout objects, not a string.
            For examples see Adobe doc, e.g.:
            http://help.adobe.com/en_US/flex/using/WS0141D24B-6AEB-4721-BA04-9BF15F86350F.html
            • 3. Re: Simple Layout Question
              mr_payne Level 1
              Thanks gang..!
              So is it possible to change the layout on the fly...
              my original attempt is to make
              [bindale]
              public var someLayout = "Horizontal";
              and then go
              someLayout = "Tiled";
              or
              someLayout = "Verticle";
              • 4. Re: Simple Layout Question
                Shongrunden Adobe Employee
                As mentioned earlier you have to work with objects not strings.   Here is an example of what I believe is what you are trying to do:
                               xmlns:s="library://ns.adobe.com/flex/spark">
                    <fx:Script>
                        <![CDATA[
                            import spark.layouts.supportClasses.LayoutBase;
                            [Bindable] private var someLayout:LayoutBase;
                    </fx:Script>
                    <fx:Declarations>
                        <s:HorizontalLayout id="horizontalLayout" />
                        <s:VerticalLayout id="verticalLayout" />
                        <s:TileLayout id="tileLayout" />
                    </fx:Declarations>
                    <s:controlBarContent>
                        <s:Button label="change layout to horizontal" click="someLayout = horizontalLayout" />
                        <s:Button label="change layout to vertical" click="someLayout = verticalLayout" />
                    </s:controlBarContent>
                    <s:DataGroup layout="{someLayout}" itemRenderer="spark.skins.spark.DefaultItemRenderer">
                        <s:dataProvider>
                            <s:ArrayList>
                                <fx:String>one</fx:String>
                                <fx:String>two</fx:String>
                                <fx:String>three</fx:String>
                            </s:ArrayList>
                        </s:dataProvider>
                    </s:DataGroup>
                </s:Application>
