1 Reply Latest reply on Feb 10, 2011 1:46 AM by rohsin47
    approval container customization issue
    rohsin47
      while creating custom approval container as descibed in "customize workspaceUI" doc, i m getting the below error.
      ReferenceError: Error #1056: Cannot create property taskform on lc.procmgmt.ui.task.TaskRouteCommandBarModel.
      at MethodInfo-10361()
      at mx.binding.utils::BindingUtils$/bindProperty()
      at FormAreaModel/configureLoadForm
      at custApprovalContainer/returnWorkspaceSession()
      at custApprovalContainer/__lcconnector_setWorkspaceData()
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at lc.procmgmt.ui.task.form::TaskSWFForm/fetchDataHandler()
      The reason and how do  i correct this?
        • 1. Re: approval container customization issue
          rohsin47 Level 1
          got it..
          no wories.
          but i thnk, it would be better if a clear distinction is shown between two parmeters in BindingUtils.bindProperty() .
          this is what given.
          BindingUtils.bindProperty(taskRouteCommandBarModel, "taskForm", this, "taskForm");
          so here one need to note that 2nd and 4th are differnet parameters, not the same, 2nd is taskRouteCommandBarModel object; property - taskForm and 4th is property u have defined in your custom class to which u r going to bound 2nd parameter.
          now what i did is i thought them to be same and defined as same . so actually what i did that i have defined var as taskform:taskForm and so in the method and then i got stuck with the above error.
          after a litle bit reading in actionscript ref., i got it.
