2 Replies Latest reply on Feb 11, 2011 6:41 AM by dharmes
    loading external file
    dharmes
      i have created plain text field and managed to load it from external file using the AS3 code below. Now i want to load multiple text field but this time in a button, how can i do that?
      this is my button code: proposal_btn
                                        story_btn
      var textLoader:URLLoader = new URLLoader();
      textLoader.addEventListener(Event.COMPLETE, textLoaded);
      textLoader.load(new URLRequest("assets/welcome.txt"));
      var dragRect:Rectangle = new Rectangle(drag.x,drag.y,0,bar.height - drag.height);
      drag.addEventListener(MouseEvent.MOUSE_DOWN, dragMouseDown);
      function textLoaded(evt:Event):void
      info_txt.text = textLoader.data;
      function dragMouseDown(evt:MouseEvent):void
      drag.startDrag(false,dragRect);
      stage.addEventListener(MouseEvent.MOUSE_UP, dragMouseUp);
      addEventListener(Event.ENTER_FRAME, scrollText);
      function dragMouseUp(evt:MouseEvent):void
      drag.stopDrag();
      stage.removeEventListener(MouseEvent.MOUSE_UP, dragMouseUp);
      removeEventListener(Event.ENTER_FRAME, scrollText);
      function scrollText(evt:Event):void
      var percentScrolled:Number = (drag.y - bar.y)/(bar.height - drag.height);
      info_txt.scrollV = Math.round(percentScrolled * info_txt.maxScrollV);
        • 1. Re: loading external file
          I am not really sure of the question, but here's an example using your info_txt code such that clicking the story_btn will load it... you should be able to use this as an example for others...
          var textLoader:URLLoader;
          function loadStory(evt:MouseEvent):void {
               textLoader = new URLLoader();
          story_btn.addEventListener(MouseEvent.CLICK, loadStory);
          function textLoaded(evt:Event):void {
          • 2. Re: loading external file
            dharmes Level 1
            excellent. Now if i want to load another text field on proposal_btn, can i do this:
                 textLoader.load(new URLRequest("assets/welcome1.txt"));
            proposal_btn.addEventListener(MouseEvent.CLICK, loadStory);
