1 Reply Latest reply on Feb 11, 2011 5:14 AM by moccamaximum
    How to Run JSFL using AS3
    sreenuvedala_547 Level 1
                Hello Everyone,
      i need to run JSFL file using Actionscript 3.0 in AdobeFlashCS5. I need to run the JSFL file on a button click.
      can anyone solve this for me??
      Thanks in advance,
      sreenu
        • 1. Re: How to Run JSFL using AS3
          moccamaximum Level 5
          Warning: Only use jsfl files if you have an idea what they actually doing. (Look up the code)
          1. you can simply open the jsfl file in flash and press the run/play button. The Script will start.
          2. If you want to have it somewhere in the menustructure of flash ^you will need to find the path where your installation put all the other jsfl files. This one should be easy to find out yourself
